Severe Misfire issue - Bimmerfest - BMW Forums
Old 04-01-2020, 01:50 PM
Auggie1959 Auggie1959 is offline
Mein Auto:
Please help..... I am brand new to this forum (well posting anyhow) I have been using it as a research tool for months.
I have a 2006 325xi E90 N52 Sedan
I've had the vehicle a month now and can not solve a couple issues for the life of me !
I have read the manual front to back and searched everywhere and cant resolve ....
I am having misfire codes on 4/5/6
But I can not resolve this .....
I have just recently changed- replaced the plugs/coils/alternator/cleaned the vanos/ new MAF & intake:.::::::::.&
Changed the oil
I got NGK plugs / OEM coils
The spark plugs were pre-gapped and everything looked good before I installed it..
I am sure they were pressed down all the way, and everything was tight fitting.
When it idles, It's horrible and I feel like it's gonna die. It shakes hard, sputters, and feels terrible. I went driving around to see how it would do, and it wasn't very well.....
I can see two places on the coil wiring harness where the wires have a slit and become exposed. One just beneath the coil pack connector head on coil # 3. & one on coil # 6.
I covered both slices with liquid electrical tape & the misfires on 1-2 & 3 disappeared. But 4/5/6 remain.
I did remove the plugs and check them today and they smelled a bit like gasoline ....
I'm going to replace injectors and see what happens .....
Please help,
Do I have to replace wiring harness ?
Old 04-01-2020, 05:46 PM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
Have you tried clearing the codes? Sometimes the misfires set a permanent code which blocks the ECM from triggering the ignition coil until you reset it.
2006 E61 MT
2010 E91 MT
Old 04-02-2020, 05:25 AM
marvinstockman marvinstockman is offline
Mein Auto: 1997 M#
Do a compression and leakdown test, and you may have mechanical issues.
Old 04-03-2020, 12:57 PM
Mein Auto:
Ok, here are some updates......
I pulled the fuel rail and cleaned all of the injectors really well....
I re-pulled out all of the spark plugs and double checked the gap
I re-seated the coils and made sure they were torqued perfect
I went and drove the car and it drives sooo much better.... The response is good, it sounds good, there is far less vibration, & it seems to have much more power........
BUT I am now throwing codes for misfires on
1-2 & 3 .......??
As well as a signal wire swapped code on the O2 sensor ???
I am just about to do a spark tester to check that right now. As well as compression and Leakdown test, per suggestion.....
I ordered Ista & Inpa I just need the cable to connect.
Would the O2 sensor or ESS sensor be a possible culprit ?
Old 04-03-2020, 01:06 PM
Mein Auto:
Yes, I did clear the codes via the FIXD app, and OBD scanner that it comes with....
I have done this several times, and even while driving.... At first it would drive better as I was clearing the codes.... But by the time I was back, it seemed to just be running well altogether....
Old 04-05-2020, 04:45 PM
Celticfc Celticfc is offline
Mein Auto:
1-2 & 3 .......??
Go back to your original post where you mentioned potential wiring issues with 1,2 & 3. Make sure that you do not have compromised connections and continuity before going down a rabbit hole.
Old 04-10-2020, 05:14 PM
3284me's Avatar
3284me 3284me is offline
Mein Auto: 2011 328 xdrive
Did you change all the coils?
2020 X5 xdrive 40i Tanzanite Blue / Coffee Vernaska
2011 328xi. Space Grey
Old 04-10-2020, 05:21 PM
Jorbabcnman Jorbabcnman is offline
inquieto
Mein Auto: bmw f20
El sensor de oxigeno a menudo se ensucia y solo es posible su sustitución.
