Vibration on mild acceleration - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 05-20-2020, 11:23 PM
rayanmehr79 rayanmehr79 is offline
Mein Auto: 74i F01 2012
Hi Guys,
New to the forum. I am having vibration on mild acceleration. Mainly round 2000 rpm and 60 km.
If i push the acceleration it will go away. I suspect the guibo fail .. but not sure
Has anyone else had this issue ?
Cheers
Sent from my ELE-L29 using Tapatalk
Old 05-21-2020, 07:53 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Originally Posted by rayanmehr79 View Post
Hi Guys,
Cheers
That would sound like more like a coil pack issue, not the Guibo joint. Not knowing how many miles you have, the tranny fluid could be low, or need changing. The Guibo joint is more like a jerk on start or downshifting.
Old 05-22-2020, 12:37 PM
KGB_SSSR KGB_SSSR is offline
no fear
Send a message via ICQ to KGB_SSSR
Mein Auto: e34 535i
Do you have x-drive?
If yes, pull off fuses in right side of the trunk that supply transfer case.
Dont pay attention to errors on the kombi, it is not so scary.
If vibration goes away, than you need to repair transfer case
