335xi cheap - Bimmerfest - BMW Forums
Old 07-31-2020, 09:14 PM
Garyconn Garyconn is offline
Mein Auto:
335xi cheap
Hello everyone. This is my 2nd time posting on here. Iíve always wanted a bmw or Mercedes and just purchased a Mercedes wagon (wife won the argument). So I found a 2011 335xi w/120k miles on it. Extremely clean car with brand new tires. Iím picking it up in the morning however, it has an engine knock. I do not know much about it except it sounds like a belt slapping the underside of the hood. Iím buying this cheap, and I know itís a gamble, but I think Iím doing the right thing (wife disagrees). Iím sure more info is needed but any thoughts on known issues. It has been serviced at the dealer pretty much itís entire life. Iím not sure if it can be repaired, or a replacement engine is in order. Iíll know more tomorrow morning. Thank you
Old 08-01-2020, 05:50 AM
dukedkt442's Avatar
dukedkt442 dukedkt442 is offline
Anti-Hack
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: 2008 BMW X3
If it indeed has a rod knock, I hope youíre getting the car for free because the fix will not be cheap. Diagnosing a rod knock is often more of an art than a science and an experienced mechanic can do it by feel. A mechanics stethoscope can help. A rod knock typically has a deep, guttural sound to it; is the sound present at idle, disappear under load, and reappear under no load when the engine comes back down to idle?
There are other sources of similar noises; my E46 had a ďknockĒ that was due to a loose belt tensioner.
If the noise is lighter ticking from the top end, likely is a lifter issue (wrong oil will due this).
Examine the oil for glitter, glitter doesnít lie.
And of course, check that the belt isnít actually ďslappingĒ anything.
The "need to have my head examined " E21 build thread
2008 BMW E83 1981 BMW 320i
2016 Chevy Silverado 2011 VW Jetta
1984 GMC S-15 1986 Oldsmobile 442
Another half dozen '60s tractors
Old 08-01-2020, 07:35 AM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
Happy wife, happy life. A 335 can be a very expensive car to maintain due to the turbos.
Given the choice, I'd rather have the BMW over the Merc due to Mercs predatory practices.......
2006 E61 MT
2010 E91 MT
Old 08-01-2020, 07:36 AM
2006 E61 MT
2010 E91 MT
Old 08-01-2020, 09:25 AM
Mein Auto:
I just got home with the car. The noise or knock us definitely coming from the upper or top part of the engine. That's all I have figured out for now. I don't have time to dig into it right now. It'll be a few weeks before I can mess with it. We're trying to get into a new home. I'll update when I know more. Thank you for the replies.
Old 08-01-2020, 09:34 AM
moosaud1998's Avatar
moosaud1998 moosaud1998 is offline
Mein Auto: 2009 BMW 328XI
I wound't have brought that car
Old 08-01-2020, 09:45 AM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
Soooooo what did you pay for the car?
[click me]
[click me too]
Engine knockin'? Drive gently and [click on this]
Old 08-01-2020, 12:45 PM
evilzoom evilzoom is offline
Mein Auto:
How cheap we talking about? If it's knocking then most likely your engine has a spun bearing! Hints why they sold you the car cheap!
Old 08-01-2020, 05:33 PM
dukedkt442's Avatar
Anti-Hack
335xi cheap
If itís knocking front the top end, you at east should be able to get away with only pulling the head.
Do an oil change. When I got my E83 back it knocked like an SOB, but when I drained the oil molasses came out despite 1 mile being on the oil. The shop that did it for my renter used horribly wrong oil. A quart of MMO and proper oil cured that. Weíre now 30k miles later.
The big thing is 1) correct notice of the noise 2) correct description of the noise 3) correct interpretation of the description of the noise. Iíll posit that a knock from the top end is NOT a spun or worn main or rod bearing.
Old 08-01-2020, 06:41 PM
Originally Posted by dukedkt442 View Post
Iíll posit that a knock from the top end is NOT a spun or worn main bearing.
But if not, what could be knockin'?
Marvel Mystery Oil's primarily mineral oil....just sayin'.
Old 08-01-2020, 07:18 PM
Mein Auto:
I'll posit that a knock from the top end is NOT a spun or worn main bearing.
Worn cam or valve...? It would have to be something that the previous owner was aware of and the reason to why it was sold cheap! Couldn't fix it himself and found it would be expensive to fix? Just speculation from my part..
Old 08-02-2020, 04:30 AM
dukedkt442's Avatar
Anti-Hack
335xi cheap
Any number of things, from valvetrain components (like worn cam phaser) to loose accessories to loose flexplate bolts. Even wrist pins. A mechanics stethoscope is invaluable.
Marvel mystery oil has brought back to life, and quieted, many an engine. Just sayiní.
Sent from space
Last edited by dukedkt442; 08-02-2020 at 02:08 PM. Reason: Autocorrected miscorrection
Old 08-02-2020, 07:46 AM
Any number of things, from valvetrain components (like worm cam phaser) to loose accessories to loose flexplate bolts. Even wrist pins. A mechanics stethoscope is invaluable.
Right on! Garyconn, do the acid test: MMO available just about everywhere - add & post result, please.
