Logic 7 DIY Amp Repair - White Goop? - Bimmerfest - BMW Forums
Old 08-01-2020, 01:40 PM
StealthCar StealthCar is offline
Mein Auto:
I have a 2007 335i e92. My stock amplifier has water damage and I received the SOS error that has deprived me of my radio sound. I am in the process of cleaning the circuit board of the amp with Isopropyl Alcohol.
However, I found this white goop on some of the parts and I am not sure if it is a type of glue or something else. It remains wet and does not seem to dry. I have attached the pictures for everyone to see.
Does anyone know what this is? And can I just wipe it off?
Name:	Photo on 2020-08-01 at 3.36 PM.jpg
ID:	902901   Click image for larger version
Name:	Photo on 2020-08-01 at 3.38 PM.jpg
ID:	902903   Click image for larger version
Name:	Photo on 2020-08-01 at 3.37 PM.jpg
Old 08-01-2020, 01:53 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
That is called Heat Sink Compound and is used regularly to improve
heat dissipation on electronic devices that get Hot.
It is often between the device and metal finned blocks
of metal.
You can find it at any decent Electronics Store or Online.
Clean it off with alcohol and put a new coat on before reassembly.
The metal cover in your last picture is what conducts the heat away.
https://www.techspray.com/transistor...-sink-grease-2
Good Luck
Old 08-01-2020, 02:33 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
+1
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 08-01-2020, 06:50 PM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
Thermal paste. Note the big metal part sinks heat really well....paste assists in moving heat from hot parts to heat sink, often a paste filled with metal like silver nanoparticles + other thermally conductive material.
Overheated electronics will fail, often quickly!
Arctic's popular....
Old 08-02-2020, 09:17 AM
Mein Auto:
Thank you! That was very informative and I greatly appreciate it!
@ctuna and @CALWATERBOY TRE
335i, 335i 2007, circuit board, diy, e92, goop, logic 7 amp, logic7, sos error, white goop
