Looking at a 328i - Bimmerfest - BMW Forums
Old 08-01-2020, 08:07 PM
Intruder196 Intruder196 is offline
Mein Auto: 944
Looking at a 328i
Like the title says, I'm looking at a possible purchase of a 328i. What are the common known troubles with this model. I currently own a 2000 740il for the past 6 years and have fixed quite a few things on this car myself. I'm looking for pro's and cons on the 328i. Is there a specific year range to avoid? One that I am looking at, have driven and would like to buy is a 2009 model.
2000 BMW 740il sport
Old 08-01-2020, 08:24 PM
moosaud1998's Avatar
moosaud1998 moosaud1998 is offline
Mein Auto: 2009 BMW 328XI
Old 08-02-2020, 03:42 AM
CALWATERBOY TRE's Avatar
CALWATERBOY TRE CALWATERBOY TRE is offline
Mein Auto: E93 335i, somewhat mod
Yo
Old 08-02-2020, 03:46 AM
Ho
Prevention
Old 08-02-2020, 09:12 AM
edycol edycol is offline
Mein Auto: 328i xDrive 6MT
Accessory belt. Change it immediately with tensioner.
Valve cover gasket.
Oil filter housing gasket.
Oil pan gasket.
Water pump is ok, better than N55, but plan 80-100k lifespan. Some do more, some do less.
And as any BMW, be proactive.
Old 08-02-2020, 09:39 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
https://www.e90post.com/forums/showthread.php?t=1517476
Old 08-03-2020, 07:22 AM
Mein Auto: 944
Thanks, This was real helpful
Old 08-03-2020, 03:52 PM
Mein Auto: 944
Great links. The last one was the most informative. I suppose I will need to either verify one I am interested in has never shredded a belt, or plan to replace the associated gaskets and tensioners to make sure this doenst happen anytime soon after purchasing.
Old 08-03-2020, 03:53 PM
Mein Auto: 944
Valve cover gasket.
Oil pan gasket.
Thanks,
This sounds like a plan of action I will take right after a purchase if there is no proof it has already been done.
Old 08-03-2020, 05:42 PM
Thanks,
Spend a little more - click on prevention link in my post above.
You don't mention mileage & maint history - more info would be good. Don't bother to change the belt if low mileage unless something's leaking that can be on the belt or it's clear it needs replacement. Usual culprit's an oil leak.
Old 08-04-2020, 05:29 AM
Mein Auto: 944
I have a few that I'm looking at but the one I leaning towards has 120k on the odometer. So based on everything I'm reading here it's imperative that I either verify these fixes have been done, or plan to do them soon after buying.
