HELP 2000 Z3 Battery Drain - Bimmerfest - BMW Forums
Old 02-17-2007, 04:23 PM
Donnaz3 Donnaz3 is offline
Mein Auto: 2000 z3
I am so disgusted. I have owned a beautiful Z3 for over 1 year- seldomly use it, have replaced the battery twice. Something is draining the battery. Am I supposed to start it daily? Anyone have any ideas? Thanks.
Old 02-17-2007, 04:56 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
There seems to be a lot of thing in the Z3 that draw power even while it is just sitting. Many people who don't drive their cars a lot have a battery tender to keep the battery healthy. I usually drive mine at least a couple of times a week, but the past few months have just dumped snow on Denver and there was about 6 or 7 weeks I couldn't get it out. When I first started it after the snow melted it just did turn over and start. I would guess that any time it sits for a couple of weeks or longer, it would be a good idea to have a battery tender attached.
Ken
Old 02-17-2007, 07:00 PM
mharrison mharrison is offline
Mein Auto: 2000 BMW Z3 2.8 Roadster
Put a an ammeter or multi-testor between the positive battery cable and the positive post of the battery set on amps. Disable the trunk light. (I propped my trunk open with a screwdriver that poked in the switch for the light.)
You should see <50 milli-amps being pulled at rest with nothing on. (It takes a few minutes to go into rest mode.)
If you see more, pull fuses one a time until it drops. This isolates your circuit. Then whip out the trusty wiring diagram and determine what that fuse feeds. You can unplug components one at a time.
Mine was a bad sub amp. The antennae base was leaking water on it and shorted it such that it was on all the time.
If you are pulling <50 mili-amps at rest......Drive the car every once and while. The Z3 was built to be driven!!!!
Old 02-24-2007, 10:48 PM
Mein Auto: 2000 z3
Old 02-24-2007, 11:31 PM
paulmurphyhomes's Avatar
paulmurphyhomes paulmurphyhomes is offline
Mein Auto: M3, 745li, Speclzd FSR Pr
I know on the 7 you can switch the batt to off in the trunk and it only allows power to go to things that need to be powered... you might have the same switch.
Old 02-25-2007, 01:31 AM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
I've been meaning to post this for about 6 months...
On the subject of battery tenders, you might want to look at the CTEK 3300. I think a cigarette lighter adapter is available, it is on the Porsche branded version. Pretty easy to wire anything you want plug-wise to it.
Daniel
2002 M roadster
Old 02-25-2007, 04:15 AM
Z3SteveJ Z3SteveJ is offline
Mein Auto: 2002 Z3 2.5
I had a battery drain problem that turned out to be a short in the power seat switch on the passenger side. Dealer found the problem, which was intermittent, and replaced the switch.
Old 03-02-2017, 10:27 AM
whitecrown whitecrown is offline
Mein Auto: 2000 Z3 Roadster 5-speed
Similar problem
Car runs OK after a jump but completely drains the battery after a few days.
Similar Threads
rewiring a 2000 z3 and lock cylinder bad need idea's to start bimmerz3 E36/7 Z3 (1996-2002) 5 05-28-2007 02:14 PM
Amazing Deal on 2000 Z3! 100k miles, Good cond. $22000! Mpire E36/7 Z3 (1996-2002) 7 11-15-2006 09:00 AM
can anyone please tell me whats the differnece between a 1997 Z3 and a 2000 Z3 bally E36/7 Z3 (1996-2002) 4 11-02-2005 07:45 PM
XM and High Battery Drain tcoz Car Navigation, Audio & Electronics by BAVSOUND 3 10-24-2005 11:15 AM
For Sale 2000 Z3 2.3 nreagles Classifieds 0 09-15-2004 04:04 PM
