E-39 Dash trunk open indicator light - Bimmerfest - BMW Forums
Old 02-10-2009, 11:35 AM
regeztoy regeztoy is offline
Mein Auto: 528I
Hello All,
I've recently noticed that my dashboard trunk open indicator light is staying on even though the trunk lid is closed and latched. I've tried several fixes, replaced actuator, tried taping over the latching bar on the body side of the trunk latching mechanism tried opening and closing the trunk multiple times manually and with the inside button by the driver footwell. I even opened up the old actuator to see if I could find the sensor, not sure what the sensor looks like. ( Did notice the grey drive shaft has a beige pulley of some sorts over it. Is this supposed to be one continuous piece or seperate pieces. Any other suggestions out there any pictures would be helpful. That darned light is making me crazy!!!!
Old 02-10-2009, 01:21 PM
jglover jglover is offline
jedi knight
Mein Auto: 2000 528i
Dude, that light made me crazy for like a year until one of the members told me to look for a broke wire in the trunk loop( the one that goes from the car to the trunk lid) I had 4 broken wires! Light Gone!
Old 05-24-2009, 08:56 AM
ersmith ersmith is offline
Mein Auto:
Broken wires trunk indicator light
Had 2001 E46 (325Ci) with following problems today:
Truck would not open by key remote, or interior push button, but would open with key
Trunk indicator light on (and won't go off) in the instrument panel.
Trunk light inoperable
Conv top would not go down
Searched this community for 30 minutes looking for clues. Narrowed to trunk lock actuator and faulty wiring. Checked wiring first, as it seemed the easiest. The problem was 3 wires broken in the bundle running from the body to the trunk lid (right side of trunk in a rubber boot) and 3 more ruptured and close. Spliced 6 wires and everything aok. Check this FIRST if your trunk open indicator light is on and won't go off!
Thanks JGlover for posting numerous responses to various posts for help on this issue as the cost to fix was $8, and saved numerous hours of hunting.
Old 09-10-2009, 03:20 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I wish I had known this six months ago!
We should compile a list of all the things that can be affected by faulty trunk wiring.
a) Trunk indicator
b) CHECK LICPLATE LIGHT
c) Trunk constantly unlocks
etc.
Old 09-30-2009, 02:36 PM
roxon98 roxon98 is offline
Mein Auto: BMW 528i
Problems with trunk
I'm having problems with trunk for a few years (in the order of starting):
Lights in trunk - Not working most of time, may work once in a year
Trunk opening - Only physical key would work. No remote, no push btton (driver seat, and the bar on trunk lid)
CD changer - "CD Error"
Trunk open indicator on panel - ON even I'm very sure the trunk is closed
A friend of mine (an auto mechanic) took a loot at it before, but couldn't find any problem.
I just read this post, and then opened the cover on trunk lid to check wires. It seems everything is OK.
Any clue/suggestion to go beyond visual checking?
Old 04-24-2010, 03:53 AM
antselK antselK is offline
Mein Auto: BMW 530d (2002)
I have only: Trunk open indicator on panel - ON even I'm very sure the trunk is closed
Have checked wires, but all seams to be OK.
All lights in trunk go off, when I close bootlid (checked from inside the car).
When trunk is open and I press the button (installed trunk edge, between trunk and car) with my finger the lights don't go off - strange :S
Old 04-24-2010, 11:09 AM
delimeat52 delimeat52 is offline
Mein Auto: '02 530i Touring
The most common fault is like the picture QSilver7 showed, frayed wires. Take your housings or tape off from around them and have a good look. A good sign of wiring problems is intermittent warnings of the trunk being open, the electronic lock only working occasionally, and lights saying they're out intermittently but changing the bulb does nothing.
If that's not the case, then it may be the locking mechanism itself. I had a couple shops look at it and and try fixing it, but after no success, brought it to the dealership. They said there's a common problem in there, but I can't remember what they said it was. (sorry) I had the dealership replace it because they said that was the problem, which didn't work either.
If you get that far and you don't fix it, then it may be the GM III, which is located under the glove box. Seems relays die in there among other problems. That's where I'm at. Something on the underside of the board in the GM III is fried black. I know I've got a touring, but same principal. Picked up a used one, which isn't working! Part number matches one that should be installed in mine, but no luck. Trying to figure out if the software is different for sedans vs. touring. Anyone know?
Old 06-17-2010, 05:10 PM
lucifermkd lucifermkd is offline
Mein Auto: E39 530d
Hello everyone. I have problem with my BMW E39 530.open trunk indicator always ON.when trunk is closed.all other lights work perfectly. please help
Old 06-17-2010, 09:08 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
find a local shop that works on Bimmers. I take mine to Urban in Catonsville MD and they know everything there is to know about Bimmers. With their help I will probably keep my 1999 528 running forever.
Old 07-13-2012, 03:52 PM
Mein Auto: BMW 528i
It is the wire - I opened it further and found 8 broken wires! No wonder nothing works in the trunk.
It's a bit deep in the rubber tube. Still trying to figure out to reconnect them.
Old 08-21-2013, 03:50 PM
SteveAreno SteveAreno is offline
Mein Auto: 2001 540i Sedan
Have same exact issue. Started with the trunk release button on the actual trunk itself going dead and then got the trunk open warning all the time and now i get a license plate light warning. Opened up the loom and heres what I found. Seems pretty straightforward just splicing in some extra wire to reconnect everything but there are 2 wires (4 ends) that are broken that are both light blue with a brown stripe. No idea why BMW would do something like that. Every wire is completely different coloring and striping and 2 identical wires lol. Thanks BMW, hopefully I wont blow up my car when I reattach the wires wrong.
2001 540i-6
Old 08-21-2013, 07:01 PM
bluebee's Avatar
Thanks for the beautiful picture. I've added it to the canonical thread, so others benefit from everyone else:
> E39 Electrical Problems Traced to Trunk Lid Harness Wire Chafing (DIY Diagnostic)
As for the color and purpose and gauge of the wires, see that canonical thread for all the details.
It would be especially helpful if you can look closely at your broken wires to hazard a guess in that canonical thread as to what BMW did wrong ... as I don't think we have a consensus as to what exactly is wrong in the first place, to make them all break in the same spot.
Old 08-21-2013, 09:22 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
Sorry off topic. But Steve, where did you get your side skirts from?
Old 08-22-2013, 01:30 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
When I rebuilt the trunk lid harness I also had the two same colored wires. So it seems that WDS is wrong about the wire color codes. I just left those two to reconnect last and after conneting those I just checked everything work as it should. I made a DIY on rebuilding the trunk lid wiring harness, it can be found here.
Old 08-22-2013, 03:53 AM
bluebee's Avatar
Are you guys talking about the BROWN (ground) wires?
Or other wires?
And, if the wiring diagrams are wrong, does that canonical thread have the updated information?
