BMW Z3 trunk lid wiring problem - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > New Member Introductions
Welcome to Bimmerfest! Whether you are a current BMW owner, shopping for a new or used BMW or just interested in cars, we hope you enjoy your visit. Take a moment to introduce yourself and post a picture of your BMW for the rest of the Bimmerfest BMW community to see.
Old 10-27-2009, 12:48 PM
rushmold rushmold is offline
Mein Auto: BMW Z3
This car has only 23,00 miles on it and I just repaired my Z3 wiring/electrical problem (with the help of a friend). If your trunk light dosen't work, the alarm dosen't work properly or the tag lights don't work this is more than likely the problem. If there isn't a problem now, there will be a problem or you have a problem and don't know it. This is an easy fix and will save you a lot of head aches and $$$$.... UNHOOK THE BATTERY FIRST. The nylon clip that holds the wire harness to the hinge on the left side of the trunk has put the harness in a bind every time the lid is closed and cause the wires to break. You are able the feel through the rubber tube for broken wires or cut a slit in the rubber hose and open it to see what is broken, then split the harness where the wires are broken. If you have 2 brown wires, mark them with a magic marker before you cut. You need to cut them all because they all have fatigued in that area. Reroute the harness through the inside the trunk area through the round hole in the lower left side of the lid, put the rubber water grommets back in their holes that are out side the trunk seal area. Moving the harness to the inside of the trunk will keep the harness from binding and causing wire fatigue but there is potential for snaging onto the wire harness with luggage or over loading the trunk. Plug the wire holes in the grommets. With a small soldering pencil solder the wires back with heat shrink tubing well out of the way until all wire are soldered the use a hair dryer to shrink the tubing. Your local hardware store will have the shrink tubing and a grommet for the trunk lid hole. If you haven't had any problems with this area of your Z3, you will. If not addressed in time you could have serious problems and they will cost big $$$. This is the weakest point with this car and it should have had a recall.
Don't use your new bath towels to protect the fender and trunk, that might create domestic problems. If there are any questions please ask.
Pictures of the sequence are attached.
ID:	206078   Click image for larger version
ID:	206079   Click image for larger version
ID:	206080   Click image for larger version
ID:	206081   Click image for larger version
ID:	206083   Click image for larger version
ID:	206087   Click image for larger version
ID:	206088   Click image for larger version
ID:	206089   Click image for larger version
Old 10-27-2009, 12:51 PM
hpowders hpowders is offline
Mein Auto: BMW's: E90 and F22
Welcome!
Post on the Z3 and Z4 forum.
2015 Alpine White 228i Coupe ("El Chapo") with Sport Line, Premium Package, Black Dakota Leather, FineLine Stream Wood Trim, Lighting Package, Driver Assistance Package and Track Handling Package and those wonderful non-runflat Michelin Pilot Super Sport Summer Tires.
Old 10-27-2009, 01:17 PM
BMW_GAL BMW_GAL is offline
Mein Auto: 2009 335i Coupe
Hello and Welcome
Sig by Solidjake
2009 335i Coupe, Titanium Silver Metallic, Coral Red Dakota Leather, Gray Poplar trim, Premium package and Sports package with 19s.
Previously Owned: 2006 Audi A4 S-Line Quattro with all the belles and whistles and a B5 Imola Yellow Audi S4
Old 10-28-2009, 05:23 AM
Desolationoverdrive Desolationoverdrive is offline
XXXXXXXX
Mein Auto: nothing
Welcome to the Forum! Nice Z
Old 10-28-2009, 10:43 AM
Solidjake's Avatar
Solidjake Solidjake is offline
Radar Specialist
Mein Auto: 13 328i 6MT
Thanks for the tips! Please post this in the Z3 section.
Old 10-31-2009, 05:37 PM
Mein Auto: BMW Z3
Z3 section??
This is now in the Z3 section. Thanks for you in put. I hope this gets to everyone with a Z3.
Rgds
