Turn signal indacator bulb - Bimmerfest - BMW Forums
Old 12-12-2009, 01:34 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
My right turn signal indicator started flashing 2x normal speed compared to the left turn signal a few minutes ago. As in other cars that's a burned bulb. I need to change the front right bulb. It does not seem obvious how to get it out of there. Suggestions? Are these replacement bulbs easy to get?
Old 12-12-2009, 01:36 PM
RRsE39's Avatar
RRsE39 RRsE39 is offline
Mein Auto: 2001 530iA Sport
I have a 2001...just turn the bulb 1/4-1/2 turn like in any other car and it comes right out.
Old 12-12-2009, 01:52 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Instructions should also be in our owners manual. Look under LAMPS AND BULBS.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 12-12-2009, 02:16 PM
Mein Auto: 2010 M3
OK festers,
I see the bulb. My hand is not very big but not weak either. I cant turn the bulb out. What gives?
Old 12-12-2009, 02:32 PM
RRsE39's Avatar
Maybe grime, dirt etc. causing it to be stuck. Try to rock the plug free by going one way and the other very fast (loosen / tighten). If all else fails remove the headlight and it should be much easier, theres only 4 bolts holding it on, itd about a min. to remove it.
Old 12-12-2009, 03:07 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2016 X5, 2006 M3, 2002 M5
Very tight quarters if I recall, take your time. It will come out.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
LeMans 2002 M5, Black/Tech Graphite, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Wife's chariot - 2016 xDrive 3.5i, Sapphire over Black. M Sport, Premium, Cold Weather, Driver Assist and Plus, Luxury and MultiContour Seats, Roof Rails, Harman Kardon
Old 12-12-2009, 03:09 PM
Mein Auto: 2010 M3
Yep, very tight quarters. I got it. But now the bulb does not apprar to be blown. Plan to take the left one out and see if thant one works.
Old 12-12-2009, 03:16 PM
Mein Auto: 2010 M3
I switched out the left bulb for the right and confirmed the right bulb was actually out even though it looked ok.
Old 12-12-2009, 06:30 PM
Mein Auto: 2010 M3
A 2- pack at Walmart was $4.88 and my signals are working fine. It is a bit tight to turn out these bulbes but pretty simple. Thanks festers.
Old 12-12-2009, 06:46 PM
540 M-Sport's Avatar
Mein Auto: M550i, 540M-Sport, Scud
I find it easier to remove the entire headlight housing to change the turn signal bulb on the drivers side. Passenger side is a little easier...
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
