DIY: Hood Cable Replacement the Easy way! - Bimmerfest - BMW Forums
Old 03-18-2010, 08:51 PM
cn90 cn90 is offline
OK,
We have quite a few hood cable getting stuck recently. there are roughly 2-4 cases a month. So I put together this list of different DIYs for future reference:
The anatomy of the Hood Cable for E39:
http://bimmerboard.com/forums/posts/366665/
The broken part inside the cabin:
The Cables at the Front the Engine. Use this elegant EASY E36 DIY! Basically:
1. Three (3) Torx screws holding the latches.
Note for E36, the Fan Shroud is lifted to expose the 3rd screw. For E39, no need to lift the Fan Shroud.
2. Instead of removing the entire nose panel, you can simply grab it near the latches and GENTLY bend it up:
http://forums.bimmerforums.com/forum...d.php?t=668742
Hope this helps.
Old 03-19-2010, 04:56 AM
Fudman's Avatar
Fudman Fudman is offline
Another great (and simple!) DIY by cn90! Thanx! Keep 'em coming!
Old 03-19-2010, 12:29 PM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Bro can you move to ATL and be my personal mechanic?
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 03-19-2010, 01:11 PM
Oh my heaven brother, come up here to Omaha Nebraska, we have tons of filet mignon hehe.
Old 11-24-2010, 02:46 PM
fedup fedup is offline
Mein Auto: 2000 bmw 528i
Nah cn90 come to taxachusetts. U'll be clicking your heels together chanting there's no place like home, there's no place like home. Lol
Old 08-13-2011, 11:58 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Apparently this one snapped today:
- E39 (1997 - 2003) > Hood Cable Snapped...
Based on this information, I updated the bestlinks just now with this:
- How to replace the hood cable the easy way (1) & how to open the hood when the hood cable snaps (1) (2)
Old 11-26-2011, 12:31 PM
bluebee's Avatar
For the cross-linked record, this was opened up today:
- E39 (1997 - 2003) > 2001 5251 Hood Latch Stuck
Originally Posted by Sterling08 View Post
Hood is stuck, I pulled release lever in vehicle and hood will not release. Tried having someone push down and manipulate hood while pulling release.
Disassembled release lever on interior kick panel and used pliers to pull cable...I think if finally snapped.
Reached in from the kidney grill and pulled on cable, left passenger side of hood released...nice.
My problem is the driver side will still not release. ... I cannot access from the bottom of the car as once I removed the tire well cover to reach up and pull cable for right side.......the air box is in the way and not removable from below...no way to reach the cable for right side from under the vehicle.
Any ideas how to get to that right side cable on this model to release that latch?
These links were assembled in the bestlinks to help that user:
- How to maintain (1) and repair your hood release bowden cable (1) (2) (3) & how to replace the hood cable the easy way (1) & how to open the hood when the hood cable snaps (1) (2) & how to open the hood manually when you have a dead 12v car battery (1) [or trunk (1) (2)].
Hopefully the user will provide an update for everyone to benefit from.
Old 11-26-2011, 03:43 PM
1BadE39 1BadE39 is offline
Mein Auto: 1997 540i
just replaced my hood release cable I don't know after doing it how guys get up to $300+ to do that but it was cake! Next is the windshield washer motor and grommet
Old 11-27-2011, 09:16 AM
bluebee's Avatar
When you do 'that' job ... please post over here to let me know what was hard and what was easy ... 'cuz I still haven't gotten the courage up to try to fix mine!
- Pre-winter inspection of a user's windshield washer system (1)
Old 11-27-2011, 09:59 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Bluebee, that's happened on every car I've filled up to the top, fwiw. I'm wondering if it's a breather or something.
Mind you, the cap has a label "4.6L" on it, and I can't put more than 3/4 gal inů. that doesn't add up
'99 528i ('98/12 build). 290,000km BY29428/Royalrot
Breaking My Wallet since 2009
Old 04-13-2014, 10:03 AM
KKlop KKlop is offline
Mein Auto: '99 528i M52TU
CN,
I tried to reach the exposed part of the passenger side cable the same way as the driver side, reaching up through the grill opening. Not sure if I ever reached it. Tight fit. Do you have any tips? Thanks.
1999 528i Jet Black Sport/Premium Sedan - Dinan ECU Stage II, CAI, Scorpion Free Flow Exhaust, Rouge Pulleys, Akebono pads
Old 04-13-2014, 03:24 PM
Hi KKlop,
Re cross-over cable (connecting R and L latches):
- The driver side is easy, reach under with flashlight, one will see the exposed part of the cable. Just smear a small amount of grease onto the exposed part of the cable once a year.
- The passenger side: you are correct, it is sealed shut, impossible to get to w/o dismantling some stuff.
What I do: once a year, I spray some silicone lubricant down the latch hole, hopefully some lubricant will get to the cable. With the hood up, I operate the cabin lever a few times to spread the lubricant.
So far so good, no issues (yet).
Old 04-13-2014, 04:04 PM
Thanks, CN! Yes, I used a mirror and flashlight to grease the drivers side, thanks to your post, and greased inside the cabin. Had not done either before. I have been spraying lithium grease down both holes for years, which always loosened the mechanisms up. This is the first year I had to pull the grill to manually open the passenger side. Now it's working fine. I'm only surmising, but I think the driver side is the critical one, which, thanks to your write up, is good to go.
Old 04-15-2014, 06:23 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
I'm planning on replacing the hood cables when when weather gets warmer and was wondering should I lubricate the new cables before installing? If I should, what should I use to lubricate them? The issue with lubricating cables is that it attracts dirt.
Old 04-15-2014, 07:10 AM
It doesn't matter if it is a bicycle brake cable or E39 hood cable, the principle is the same.
Some grease is better than nothing. However, grease attracts dirt.
I usually do this:
- Once a year, around April or May when all the road salt has gone, I clean the exposed ends of the cable with brake cleaner (or something similar).
- Wipe it clean.
- Apply fresh grease.
Old 06-26-2015, 10:02 PM
syphilouis syphilouis is offline
Mein Auto: 2002 530i
does this not work on post facelift e39's because mine definitely wont bend its also riveted to another part of the core support...
Old 12-06-2017, 03:04 PM
ericono ericono is online now
Mein Auto: 1985 M635, 2000 528iT
This seemed like a good thread to continue with this topic.
My issue is the cable that goes from the handle in the cabin to the first connection joint next to the driver's inner front fender.
I called myself searching but couldn't find anything about this cable as most issues seem to be with the cables under the hood.
Does anyone have a clear DIY on this cable replacement, or at least explain a clean way to remove the inner kick panel where the handle is located?
Thanks,
Eric
Old 12-06-2017, 03:38 PM
Wgosma's Avatar
Wgosma Wgosma is offline
Mein Auto: 2012 X3 (2.8i)
Thanks,
Eric
See post #2 in this thread, some info but no real detail https://www.bimmerfest.com/forums/sho...ght=hood+cable
Bill / 2012 X3
Old 12-06-2017, 04:06 PM
Thanks, that is helpful. At least it points me in the right direction of needing to remove the dead pedal. I'll post up any comments I have after I, hopefully, successfully complete this.
Thanks again,
Eric
Old 12-06-2017, 06:26 PM
Wgosma's Avatar
Thanks again,
Eric
Good luck Eric....I sort of recall reading about the dead pedal, etc. removal of stuff in this area long ago and it's kind of an akward sort of 'twist' or the like one has to apply to get the thing out...and back in.
Bill
Bill / 2012 X3
Old 12-06-2017, 09:03 PM
...My issue is the cable that goes from the handle in the cabin to the first connection joint next to the driver's inner front fender...
Oh,
I forgot to update this forum, I posted the update for this cable (from cabin ---> first connection) on bimmerforums.
Here you go:
https://www.bimmerforums.com/forum/s...ion-Box)/page2
Old 01-14-2018, 10:37 AM
I finally got around to doing this and added detailed comments to cn90's link in the post above. Thanks to all for the help!
Eric
