Car goes into Park when door opened!? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 01-20-2011, 09:12 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
The 7 is at the dealer again and I have another 5 loaner. When backing up today, I opened the driver's door to look back to get as close as possible to what I was parking in front of and I couldn't believe it - the car abruptly stopped and put itself into Park!? I tried again - same thing! I then put the car in Drive and opened the door - same thing! Do our 7's do this? I hope not. This safety feature is not all that safe in my opinion, as I can imagine emergency situations where itd be life threatening.
Old 01-20-2011, 09:39 PM
LovinM6's Avatar
LovinM6 LovinM6 is offline
Mein Auto: 2015 750Li
This absolutely is a safety feature build into the 7. I've been through this conversation. It is a pain and I am not sure what the heck they were thinking but you can't get around it.
2015 MB Custom designo S550V . . . . . . . . . . . . . . . . . . . | 2015 BMW M Sport 750Li Individual
designo Mocha Black . . . . . . | designo Auburn Brown . . . . . | Individual Azurite Black . . . . . . . . . . | Individual Opal White
Old 01-20-2011, 10:10 PM
Yea, I don't get it either! A user from Bimmerpost, also with an Individual, seems to prefer the feature, however: http://www.7post.com/forums/showthread.php?t=478911
Old 01-21-2011, 01:43 AM
bruno787 bruno787 is offline
Mein Auto: 740Li (F02)
it does stop abruptly when you open the door.
havent got the courage yet to try it at cruising speed!!!!!!
what do you think will happen? curious....
15 Maserati Quattroporte GTS
10 740Li (gone)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4
Old 01-21-2011, 07:32 AM
LovinM6's Avatar
It won't be me trying to figure out what happens?
Old 01-21-2011, 07:39 AM
lol!!!
Old 01-21-2011, 01:16 PM
Gentlemen: Opened door at 25 MPH and Park did not engage. Tried again at higher speed - nothing. Reattempted at low speed - nothing. Then shut down and started back up, thinking that once it triggers not to engage at speed the safety feature remains off. Reattempted - still nothing!? Not sure if the car recalls not to engage for a few moments after shut down or if this should be as a part of the official 'break in' procedure or what!? Anyway, will try again at low speed to see if it works again or whether it's gone all together now...
Old 01-21-2011, 03:19 PM
texgeekboy's Avatar
texgeekboy texgeekboy is offline
Mein Auto: '14 750i, '15 535i
I noticed this feature early on. It truly is a PITA. What were they thinking?
Old 01-21-2011, 04:14 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2018 540i
On my F10 535i, it only goes to park IF your seatbelt is off AND the door is opened. If you are wearing your seatbelt, you can roll as much as you want in gear with the door open.
BMW-CCA
Bimmerfest Supporting Member
Current: 2018 540i MSport | Med Blue/Cognac| MSport Brakes | Multi-Contour | HK | ZLP
Prior: 2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather
Old 01-21-2011, 04:15 PM
markl53's Avatar
If you keep your seat belt buckled, it doesn't go into Park if you open your door.
BMW-CCA
Old 01-21-2011, 06:05 PM
texgeekboy's Avatar
I did not know that, thanks.
I will admit my seat belt wasn't buckled when I last did it, but it is still a PITA.
Old 01-21-2011, 10:29 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
The 7 is at the dealer again and I have another 5 loaner. When backing up today, I opened the driver's door to look back to get as close as possible to what I was parking in front of and I couldn't believe it - the car abruptly stopped and put itself into Park!? I tried again - same thing! I then put the car in Drive and opened the door - same thing! Do our 7's do this? I hope not. This safety feature is not all that safe in my opinion, as I can imagine emergency situations where it'd be life threatening.
The car is designed to do this at low speeds when it detects no weight on the seat mat for the driver. The old E65/66 did this as well, it's a saftey feature so in case you get up out of the car to chat with another person and forget to have the car in park. If you turn on autopark and let it hold the car for you at a redlight, lift yourself off the seat and you will see the symbol turn from the normal green to red to show that the full parking brake has engaged.
Old 01-22-2011, 03:33 AM
gassy gassy is offline
BMW 7 Series Obsessed
Mein Auto: 2016 M4 Champagne Quartz
Damn! I guess this means that Clive Owen can't open the door and push the bad guy driver out at 150 km/hr and slip into the driver's seat, spin that Z8 in a 360 and catch some air on the next bump! See :
Old 01-23-2011, 10:08 AM
Thanks Gentlemen! Good to know.
Old 10-12-2011, 10:46 PM
Has BMW done away with this for 2012? I have a 2012 for the night and it doesn't seem to do this! I wonder if our 2009/10/11's can be reprogramed to do away with same!
Old 10-13-2011, 03:53 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
This thread explains that item I read in The Onion about do-it-yourself hybrids...drivers of high-end sedans spotted using their cars' doors as sails!
Currently: 2015 Porsche 911 GTS and 2018 718S Boxster
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 10-16-2011, 07:52 PM
ruey220 ruey220 is offline
Mein Auto: Benz
wonderful safety system BMW put in here, next time someone is trying to carjack your 7 series, they pull your door open and you try to drive away the car will put itself in park to let them get hold of you and pull you out of the car.
actually i learned this awhile back myself i was trying to roll the car 1 foot at a time to check if there is a nail in the tire, and it kept going into park.
true story though, friend of mine with the older 7 almost got carjacked in Oakland, and if it wasn't for the shifter in the steering column the thief was almost able to get away with her 7. the slight delay it took him to figure out how to drive the car away was enough time for her to call for help and for someone to beat on the guy in the driver's seat.
