steering hard and will not centre... - Bimmerfest - BMW Forums
Old 05-23-2012, 09:03 PM
One28i One28i is offline
Location: Toronto, Ontario, Canada, North America, Earth
Mein Auto: 2002 530i M-pkg manual
Unhappy steering hard and will not centre...
A month ago, on the way to work, my E39 I6 manual trans steering went hard on me. No noise or moans when I turn the wheel, just requires a lot more effort. Also the steering @ quarter turn will not centre. Before quarter turn, it will try to centre, but still sticks to where u leave the wheel, and past quarter, it will try to centre quickly, but as it passes the quarter turn mark on either side, slows down. Speed doesn't make the steering return quicker or slower, which I also found to be odd.
Check fluid, red, and smell like dextrin ATF fluid, that what the BMW parts guy gave me a few years ago to top up.
So I removed the PS tank, to flush, and clean the filter. Have done it twice now, but the steering is still hard. I think it improved a bit when I did the flush, but the flush was whatever was in the tank, and a bit in the rubber lines.
I ran the system with low fluid @ idle no turn to see flow, and I do have flow or pressure in the system.
Is it common that the rack fails? Keep in mind, I keep all the fluid topped up. Mileage on the car is 198,000 km.
Look forward to your input, experience, and guidance.
Five30i
Old 05-24-2012, 07:57 AM
rdc8118 rdc8118 is offline
Mein Auto: 2008 X3 sport
Had the similar problem while ago. Really hard to turn and binding every quarter turn. I lifted the front end off the ground, started the engine and it still had the problem with no load. Following another persons advice from the forum, I hosed the crap out of the u joint in the steering arm just above the rack with wd40. Let it sit a little, then hosed the u joint down with white lithium grease and let it sit overnight. No more binding for the last year. As a preventative measure every couple of months I'll repeat the process.
Don't know if it will solve your problem but a spray can of wd40 and a spray can of white lithium grease is cheap and worth a shot.
Old 05-28-2012, 10:55 PM
God bless you rdc8118, I sprayed rust check, since I couldn't find where I last placed the WD40 can, and my steering centres itself. I didn't even hose it down. Just soaked it with lube. So giddy. I was preparing and pricing a pump and a rack for the car, and was going to go search for DIY on how to do it.
The steering is actually light. I think since I had the car in 2006, it has had a hard steering. Thought it was a BMW thing.
To think a bit of lube solved this major headache I have been having for a month now.
Once again, thank you.
Five30i
Old 05-28-2012, 11:41 PM
Tommylaw9 Tommylaw9 is offline
Boss Hogg
Mein Auto: 2001 530i
can someone take a pic of where this should be sprayed?
Old 05-29-2012, 12:17 PM
mrpumpk1n mrpumpk1n is offline
Mein Auto: 540i 1997
same request as tommylaw as above. im having the same problem but on v8
"Owning any german car is like hanukkah,
every day another light"
Old 05-29-2012, 07:12 PM
http://bmwfans.info/parts/catalog/E3...oint_assembly/
If you look at the lower joint steering assembly, just above where the screw number 2 goes, that is where you need to lube it.
It is hard to take a pic from above, its a tight fit, but if you aim right, u can get a direct hit.
Also from the bottom if exposed, but I didn't raise the car.
Also need to soak it over night, and if you hit the right spots on the u-joint, you will know right away when you turn the wheel.
Enjoy this best DIY maintainance tip to ensure your Bimmer gives the feed back it as designed for.
Five30i
Old 04-02-2014, 02:28 AM
colino colino is offline
Mein Auto: 523SE
I realise that was an ancient thread, but before I checked the codes (assuming a module was down!) I searched and found this nice, basic answer.
Timely reminder to check the basics first and do a simple fix instead of condemning perfectly good parts because we've become accustomed to elderly electronics giving up the ghost.
Thanks to all.
Old 04-07-2014, 01:58 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
Thanks to all.
+1 Remarkable how much drag the steering column U-joint can cause. Replaced PS pump to no avail; Ordered a rebuilt rack & pinion; Then I discovered this thread. A couple of squirts of lube on this joint and all is well! Rebuilt R&P will be returned unopened.
'12 328i Cab Deep Sea Blu/Tan
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 04-07-2014, 03:16 PM
musa's Avatar
musa musa is offline
Mein Auto: E39, E53, E92, F86
This is incredible! I've been having somewhat similar issue and just accepted it and lived with it. I thought an indie who used to work on my car messed up something when he replaced the tie rods years ago. I will definitely lube that part!
_____________________________________
E39 528ia, E53 X5 4.4 Sports, E92 335i, F86 X6M
Old 09-04-2019, 06:43 PM
xenopherous xenopherous is offline
Mein Auto: 1999 BMW 528i
This is the diagram to that u joint if anyone's wondering
