Retrofit Paddle Shift in F10 - Bimmerfest - BMW Forums
Old 05-14-2013, 07:47 AM
theMpower theMpower is offline
Mein Auto: F21 125d
Coding Ok, only change the steering wheel and coding for retrofit SAT in F10
Old 05-14-2013, 07:20 PM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
Please take a look at this thread. I believe this should give you what you need. Good luck and let us know how it turns out.
https://www.bimmerfest.com/forums/sho...&highlight=dec
Old 05-11-2014, 11:56 PM
madoon madoon is offline
Mein Auto: 2014 BMW 520i
hi,
any updates on this, did it work?
thinking of paddle shifters to my car, do i just need buy the steering wheel with paddles and SAT gear shift or is there more to this?
Old 05-12-2014, 03:30 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Yes, that is it. You may need new Airbag with the wheel depending on your existing wheel.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 05-12-2014, 04:24 AM
ap90500's Avatar
ap90500 ap90500 is offline
Mein Auto: F30 320d xDrive -14
No need for SAT gearshift, normal one works fine.
Old 05-19-2014, 04:45 PM
does this require coding or changing the wiring?
cant find info if the wiring needs changing or any modifications
i have a new LCI and need to change the steering wheel to add paddle shifters.
Old 05-19-2014, 08:34 PM
It should just be new Steering Wheel and Coding for F10.
Old 05-20-2014, 12:16 AM
ap90500's Avatar
Yep, I have done this.
Old 06-04-2014, 02:55 AM
jayr111 jayr111 is offline
Mein Auto: 520 D Auto F10
Information
Hi , I have got the paddleshift steering wheel. Can you message me on how you did the retrofit? I have a 520 D Se Auto
Thanks a lot for your help.
Cheers
Jay
Old 06-04-2014, 02:58 AM
Replace Steering Wheel, add 2TB to FA, and VO Code ICM and EGS.
Old 06-04-2014, 03:12 AM
Wow. Shawn that was quick and precise. Is there anyone in London, Uk who can help me with this? my first BMW so dont want to mess this up !
Thanks Jay
Old 06-04-2014, 03:31 AM
I can't help you there...
Old 07-18-2014, 04:56 AM
julesandtrish julesandtrish is offline
Mein Auto: 2010 335d
I already have the M-sport steering wheel (2014 LCI) on my F10. Can I just add the shift paddles?
Old 07-18-2014, 08:04 AM
I'm not sure on LCI Wheel, but for Pre LCI, you need to replace the entire Wheel with a Wheel with Paddles as the base for the paddles are molded into the wheel.
Old 09-01-2014, 07:16 PM
sam-and-dori sam-and-dori is offline
Mein Auto: 535i
Hi Shawn. What value should I change in ICM and EGS after added 2TB?
Old 09-01-2014, 07:59 PM
If you at 2TB and VO Code ECU's, it will set the coding for you automatically. That is the whole point of VO Coding, so you don't have to make individual FDL Code changes.
Old 11-29-2014, 04:24 PM
bestb bestb is offline
Mein Auto: F10
How about if I buy paddle shifters only ? can I add them to my steering wheel ?
Old 11-29-2014, 07:41 PM
No. The Paddle bases are molded into the wheel. You won't have anything to mount them to.
Old 11-30-2014, 03:21 AM
Mein Auto: F10
Old 01-16-2015, 03:31 PM
jdjatt jdjatt is offline
Mein Auto: '14 535i
Which ECU needs to be coded? KOMBI and ICM ?
Coded
Custom SMG Steering wheel with Shift Paddles
Old 01-16-2015, 03:53 PM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
As written in post #10, if you want to add 2TB you have to code EGS and ICM.
For paddels there is no need to code a hole ECU. One entry in SZL is enough.
CU Oliver
BMW G20 330e in tansanit 2 blue, all in )
Jaguar XK8 4.2 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 01-16-2015, 07:57 PM
Mein Auto: '14 535i
Originally Posted by milkyway View Post
Hello!
CU Oliver
This is what i did, I edited the VO
Loaded the file and flashed the new VO
after that i flashed ICM and EGS
I have the sports+ mode now also
But the paddle shifters don't work
Flashed KOMBI also to be sure.
I had a standard wheel on my 14 f10 before that i replaced.
UPDATE: coded SZL with Lenkrad_Schaltpaddles -> nicht aktiv. Paddle work now. But they dont light up and display still has M1-M8 not S1-S8
Coded
Old 04-27-2015, 03:55 AM
Afsar Afsar is offline
Mein Auto: BMW F12 650i Convertible
In a 2013 F10 standard steering without paddles do I need just new steering with paddles and coding? Link in 2nd post of this thread talks about wiring as well.
Old 04-27-2015, 07:13 AM
No wiring changes are needed.
Old 06-21-2015, 12:20 PM
Undergnd5 Undergnd5 is offline
Mein Auto: 5
I everyone,
New to coding but very much interested in getting paddle shifters to work on my 2010 F10.
I already installed the steering wheel.
From what I gathered above I should only have to change one entry in the SZL module. Sadfully, my SZL module does not have that entry, the only steering wheel (Lenkrad) entry it has is Lenkrad_Vibration.
Will I have to insert the entry myself?
