Custom CAFD Tool - Bimmerfest - BMW Forums
Old 09-26-2013, 04:18 AM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
Custom CAFD Tool
Update: 12/07/2013 V0.2.3 Alpha
  • Added FA Compare
  • Minor Bug fixes
- language.en.xml is a separate download now so as not to overwrite your local copy. If you don't have a local db yet, you can download language.en.xml and place a copy where the tool is
You can just replace/update "NcdCafdTool.exe", no need to update/replace .config and .dll files
NcdCafdToo_V0.2.3.zip.pdf
Update: 11/20/2013 V0.2.2 Alpha
  • Added Full Support for PSdZ 51.1
  • Fixed an issue that could happen in OS with different locale. You have this issue if you get the message: "Data at the root is invalid"
If you have customized the settings, don't overwrite "NcdCafdTool.exe.Config" or your settings will be replaced. Open "NcdCafdTool.exe.Config" with Notepad, copy the value of signatureKey node, then open the application, go to Settings and replace the Signature Key. You can also edit your config file with Notepad.
NcdCafdTool_V0.2.2.pdf
Update: 10/27/2013 NCD / CAFD Tool V0.2.1 Alpha
  • Added FA/Available Options (Salapa) Search function
  • Added FP Search function
  • Minor bug fixes
Last release should have been labeled V0.2.0. , so this is now V0.2.1
No change in config file, so you can just extract the executable and overwrite the old one
Attachment 404320
Update: 10/23/2013 V0.1.3.0 Alpha
  • Added FA/FP Viewer
Attachment 400816
Update: 10/13/2013 V0.1.2.1 Alpha
  • Fixed Disabled Client ID/Secret Text Boxes
  • Fixed Search Error when reaching the last matched item
  • Added Side-Window Translation
  • Added Translation in "Compare" panel. Uses local language DB only. Load NCD/CAFD in NCD Viewer to populate local DB
Update: 10/13/2013 V0.1.2 Alpha
- Added Translation https://www.bimmerfest.com/forums/sho...8&postcount=47
- Fixed issue with "Search"
- Now uses .NET Framework 4.0
Update: 10/6/2013 V0.1.1.3 Alpha.
- Fixed issue with 'UNBELEGT'
Update: 10/4/2013 V0.1.1 Alpha
Update: 10/4/2013 Added Attachment
Rename .pdf to .zip
Trying to get a feel if the coding community is interested in a tool like this:
http://i.imgur.com/JHfGNjO.png
I started writing this tool a couple of hours ago, very rough in its current stage but could be developed further and make it smoother around the edges a bit.
Currently, the only thing this tool does is decrypt CAFD and present it in tree view, nothing else. What's interesting is that names are mostly in English, so, the non-German tongue among us, could readily understand it.
I've been talking to Shawn several weeks back on a related tool and this could be the start of it. This tool can lead to comparing between two NCD files, or even NCD to CAFD, or CAFD to CAFD files. Anyway, before I get ahead of myself, just wanted to see if anyone is interested in this type of tool. I can develop it further, elicit some ideas, and release it to the community - free of charge.
Note: I'm contemplating if I should make this open source, but since it entails decrypting CAFD using the maker's private key, I'm not sure if this is a good idea.
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Last edited by TokenMaster; 12-07-2013 at 01:18 PM. Reason: Updated Content for V0.2.2
Old 09-26-2013, 07:39 AM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
I think a tool like this would be infinitely valuable to be able to search for codes and for comparing what settings are changed when different VO options code are changed.
For the German names and comments, could you also add an interface to Google translate (or something similar) so that this text could be shown in both the original form, and in whatever language the user prefers?
Old 09-26-2013, 09:17 AM
Token Master
In-place translation is kind of out of the table right now as the translation API is for-fee service, but a link to G is definitely doable.
I'm working on NCD file parsing now and have a working code set. Next on the to-do list is to feed/merge it with CafD to come up with something similar to the above. Comparing between NCD files should be relatively quick after that. When that's done, I'll release an alpha build
I find it amusing that the CAFD files are about 80% English in its raw form -at least the DME CAF. E-Sys does on-the-fly translation to German, even if English is selected as a language. I guess this is a bug, but I don't know.
Old 09-26-2013, 01:21 PM
gspannu gspannu is offline
Mein Auto: F10 535, F82 M4
Seems to be quite an awesome idea. Especially a comparison mechanism for files. I think the Google Translate option would be quite useful too. I am sure there must be some translation API available 'free to use' somewhere.
Keep up the good work...
Old 09-27-2013, 01:00 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Bring it!
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-27-2013, 06:56 AM
mcrussell mcrussell is offline
Mein Auto: F10 520d M Sport 11/2012
Sounds like an awesome idea, currently I use Beyond Compare with NCS FSW.TRC files which is a fast way of seeing what options change in the coding of a module when you you code it based on different VO's.
Being able to compare the coding of a CIC with or without COMBOX for example would be very useful.
Old 09-28-2013, 04:28 PM
Token Master
Well, comparing NCD/CAFD was Shawn's idea
Update: NCD parsing and injecting into CAFD is done.
Next is adding the compare and search feature. UI will probably look side-by-side/left-right panel, with visual difference indicator.
I noticed that the entries are not sorted. I did made a sorted version but I thought I'd do what E-Sys does. Anyway, this can be easily added as user configurable setting.
On the translation, Bing has a free-to-use model but is limited to 2M characters per month. Maybe it's good enough for now.
Old 09-28-2013, 04:34 PM
Token Master
BTW, just like E-Sys, when opening an NCD file, it will determine and open the corresponding CAFD file withough having to browse for the file.
Old 09-30-2013, 06:47 AM
bmwgcyr bmwgcyr is offline
Mein Auto: BMW m550i xDrive 2018
I am interested as well, that would be an awesome tool!
BMW G30 m550i xDrive 2018
Born: 2018-09-11
Carbon Black, Black Nappa with Grey Poplar. Pkgs: Premium, Adv Driver Assist, Remote Parking, 668M 20 In, Adaptive suspension & Smartphone
Z1Q, ZC5, ZK9, ZTV, 29X, 2VW, 4LQ, 4161, LZFK
Mods: none for now
Other:
BMW R1150RT 2005 LE, night black
Retired:
BMW F10 550i 2011 m-sport & Meistershaft GTC Exhaust
BMW e60 545i 2005 m-sport 6mt
BMW e39 540i 2000 6mt
BMW R1100RT 2000
[/SIGPIC]
Old 10-04-2013, 06:11 AM
Token Master
NCD/CAFD Tool Alpha 1.0
Ok, time for Alpha1.0 Release. Expect bugs and please do report as you encounter them. This requires a properly configured PsdZData folder and .NET Framework 3.5+. First thing to do is to tell the tool where to find PsdZ folder, usually C:\ESysData\psdzdata
NCD/CAFD Viewer
Browseload NCD or CAFD file and it will be presented in the tree view. Button next to browse button is for refreshing/reloading.
Search box is above the treeview control. Button with stacked disks icon is used to show/hide storage node
As you click on the nodes, the grid view will reflect the location of the selected setting within the NCD file. Clicking on the grid will automatically expand the selection and will update the tree view as well.
Textbox on the right shows the current data group, selected function, current value and available options
Old 10-04-2013, 06:16 AM
Token Master
NCD/CAFD Comparison Tool - Tree View Mode
Select left-side file. Button next to left browse button is use to compare NCD against default values in CAFD
Select right-side file and press "Diff" button next to it to compare it against the left-side file.
Difference will be highlighted and you'll aso get a summary of difference in another window.
Old 10-04-2013, 06:20 AM
Token Master
NCD Compare Tool - Grid Mode
Select files and compare from the Tree View tab. Difference are again, highlighted. This is only available when comparing NCD files
With this this, you can compare CAFD files from different versions of PsdZ and inspect the difference among available versions
Old 10-04-2013, 06:21 AM
Awesome!
Please send me a link to download and test it.
Old 10-04-2013, 06:22 AM
Token Master
CAFD Decryptor
Simple decryptor and export to XML function.
Old 10-04-2013, 06:27 AM
Token Master
Originally Posted by shawnsheridan View Post
Awesome!
Added attachment to OP. Rename to .zip
Old 10-04-2013, 07:08 AM
Update: 10/4/2013 Added Attachment. Rename .pdf to .zip
I tried it and I get an error when trying to open a .NCD file from my computer, see attached screenshot: Object reference not set to an instance of an object
Name:	Object Reference not set to an instance of an object.JPG
Born: 2018-09-11
Mods: none for now
Other:
Retired:
BMW R1100RT 2000
[/SIGPIC]
Old 10-04-2013, 08:54 AM
NICE!
I like the NCD Compare functionality a lot. The fact that you can either a) Compare against the Default values, or b) Compare against another .NCD is sweet!
Thanks for making this!
Old 10-04-2013, 12:19 PM
Token Master
I'll check this file and see what's going on but did you have the PsdZ in the default location?
Old 10-04-2013, 12:22 PM
I tried it on my home laptop instead of the work computer and it is working fine. Thank you for the tool.
Guy
Born: 2018-09-11
Mods: none for now
Other:
Retired:
BMW R1100RT 2000
[/SIGPIC]
Old 10-04-2013, 12:25 PM
Token Master
NICE!
I like how I can compare CAFD versions and see the change between them lol
Old 10-04-2013, 12:28 PM
Token Master
Guy -you're welcome and glad to hear it's working now.
Old 10-04-2013, 12:29 PM
Just an FYI. The default location on E-Sys 3.18.4 is C:\ESysData, which I still use, but beginning with E-Sys 3.22.5, it changed to C:\Data.
Old 10-04-2013, 09:31 PM
Token Master
I did notice that on fresh install of V3.24, but not on earlier versions. Anyway, changed the default config to just C:\Data now, V0.1.1 Alpha out.
Apparently, XP doesn't like storing configuration in the roaming profile folder. Works on XP now. Added drag and drop feature and CAFD decrypter outputs an indented, well-formatted XML
Old 10-04-2013, 09:49 PM
You broke it:
I set my PSdZ Location to C:\ESysData and saved it, but nothing is working in this version.
Old 10-04-2013, 10:04 PM
Token Master
I should learn to refresh the settings after saving :gah:
Workaround: Restart the app after saving
bmw, cafd, e-sys, token, tokenmaster
