SWID Reader - failing to read code - IFH-0009 error - Bimmerfest - BMW Forums
Old 11-23-2013, 03:50 AM
320dd 320dd is offline
Mein Auto: bmw 320d
Hi,
I have a BMW 2011 320D and like many others would like to be able to code stuff.
For me i'm hoping to start by using SWID Reader to read off my 0001b code to then get an FSC for latest map updates.
My setup is as follows:
Environment: Win XP running in a Virtual Machine
Cable: from EUAUTOHAUS.COM here - not cheap and supposedly with lifetime guarantee
Software: links kindly provided by Shawn on here SW tools 2.12 etc
DATEN - V49 but currently downloading 51.0
EDIABAS.INI : remote host set to 192.168.68.1 PORT to 6801
OBD.INI - STD:OBD and COM port to 1 which is port cable connects on - confirmed
SWID reader is running from ediabas/bin and I copied the 4 files to the ECU directory.
So, my symtoms are:
My cable connection appears to be all good. I use DCAN tools and successfully setup the interface on 500 KBITs D-CAN immediately after plugging into OBD port in the car whilst LED is on.
Now I start SWID reader E series and reader confirms Ignition on and then on to read VIN and finally try to grab the code which then outputs the error IFH-0009 as further below.
Now I know i've not mentioned INPA ... perhaps mistakenly i'm thinking that if SWID cannot read then nothing will? Correct me if i'm wrong here?
For info INPA does detect ignition state but airbag read fails with not found object or similar not gone any further with this for now.
Personally im suspecting my cable may be the issue - can anyone offer any assistance.
tia
Pete
SWID reader log:
Starting...E-serie...
Ediabas version: 7.3.0
Ignition: = OKAY
Trying...
Reading CAS...
CAS: VIN - F025155
Setting addresse: = OKAY
Reading CIC...
CIC: VIN - F025155
System.Exception: IFH-0009: NO RESPONSE FROM CONTROLUNIT
Total bytes: 0
------------------------------------_a_
Old 11-24-2013, 09:08 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
SWID Reader with DCAN is known not to work. You need to use ICOM.
Most FSC Code sellers only need your VIN, so pulling your 1B file isn't even needed.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 11-25-2013, 12:29 AM
Mein Auto: bmw 320d
Thank you Shawn I wasn't aware of that.
That being the case maybe my coding setup and cable is in fact good - I need to test further.
Is ICOM a tool that is available to us mere mortals from anywhere?
How does ICOM differ from INPA and NCS Expert?
cheers
Pete
Old 02-11-2014, 01:22 AM
kon kon is offline
Mein Auto: BMW
Very wishful thinking... will the SWID reader works with enet cable on E-series car? If not, what cable do I need? Is there any additional software needed for E-series? I've only been working with E-Sys on F series car!
Disclaimer: I'm just helping a friend to do this, doesn't own the car, so cannot even experiment myself
Old 02-11-2014, 04:01 AM
SWID Reader will not work with ENET and Exx car, and DCAN doesn;t work like it should, which leaves ICOM.
Additional Exx software for what? All Exx software except Tool32, INPA and ISTA is different than Fxx. What are you trying to do?
Old 02-11-2014, 06:38 AM
kon kon is offline
Mein Auto: BMW
I just want to download the 1B file from the E84-X1. the car was pretty new. And the shop i get my enet cable from state on their web that enet cable works for late e-series car. I will try nonetheless, just want to see if it's true. And if I need a separate cable and it cost as much as the enet cable, then i don't mind getting it
Old 02-11-2014, 08:06 AM
Knock yourself out, but ENET will not work with Exx. Unfortunately, neither will DCAN for some strange reason, which leaves ICOM.
Just PM me the VIN. I can make this very easy for you.
Old 02-11-2014, 08:53 PM
kon kon is offline
Mein Auto: BMW
PM sent! thanks!
Old 02-12-2014, 05:48 AM
PM sent! thanks!
Reply sent.
Old 02-13-2014, 12:59 PM
Rustys Rustys is offline
Mein Auto: E91
get excactly the same error - is it proven that DCAN will not work with swid reader on E9x?
Any other possibility to get the 0001b code with DCAN?
cheers
rustys
Old 02-21-2014, 05:10 AM
g.chris g.chris is offline
Mein Auto: F10
tryed on my wifes e90 (2010) with enet... no go (
SWID Reader not working (
she has MOTION CIC. I just want the 1B file.
How can i do this?
Tnx
Old 02-21-2014, 01:55 PM
heuteabendwo heuteabendwo is offline
Mein Auto: 525d
Reply sent.
Hi ,Shawn, I faced the same probem:
having E61, using DCAN cabel, followed the instruction, can connect the car and even read out VIN, but got the same error "IFN0009-no response from control unit".
Can you please help me generate fsc code?
Old 02-21-2014, 01:58 PM
My understanding is that SWID Reader does not work with DCAN Cable for Exx cars beginning 03/2007, and ICOM must be used.
Old 02-21-2014, 02:06 PM
Mein Auto: 525d
how does a ICOM cabel look like? any info?
Old 02-21-2014, 02:12 PM
Bmw icom a+b+c:
Old 02-21-2014, 02:36 PM
Mein Auto: 525d
Bmw icom a+b+c:
Attachment 424215
It looks like that this set is very expensive...so this leaves us only the chance to pay those code sellers to get fsc code?
Old 02-22-2014, 04:16 AM
Yes, to buy ICOM for the sole purpose of getting 1B file from Head Unit would be ridiculous. It would be much cheaper to just by Map Update code every year. The generator is useless if you can't get the 1B / DE file.
Old 06-20-2014, 09:47 AM
Genjiro Genjiro is offline
Mein Auto: bmw 635d
Got also the same Problem with the D-Can
SWID reader log:
Ignition: = OKAY
Trying...
Reading CAS...
CAS: VIN - CV18288
Reading CIC...
CIC: VIN - CV18288
Total bytes: 0
Can somebody help me please to get the 1b File ?
Old 06-20-2014, 11:25 AM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
You need ICOM to read the 1b file from E chassis.
BMW Coding for E, F and G Models - www.bmwminicoding.com
Old 06-20-2014, 11:46 AM
Mein Auto: bmw 635d
The Cable is very expensive.I just need it to generate the Key for the Maps.
Old 06-20-2014, 11:54 AM
And that is why it is just cheaper and Easier to just buy an inexpensive Map Update code than mess with it.
Old 06-20-2014, 12:45 PM
jimmy9980 jimmy9980 is offline
Mein Auto: 2013 BMW M5
He must be using an older version look for the 1b 32-64bit version it works with no issues! I did use an ICOM also !
Old 06-20-2014, 12:53 PM
SWID Reader x64 doesn't work with DCAN Interface either.
Old 07-09-2014, 01:01 PM
Griff500 Griff500 is offline
Mein Auto: 2011 E92 M3
Are you able to help with FSC codes for European maps? I have just spent hours trying to get a DCAN cable to work so that I could pull the 1b file and finally found your post saying a different cable was required!!
Old 07-09-2014, 04:13 PM
vincesd vincesd is offline
Mein Auto: 2011 328i
There's an ICOM emulator floating around somewhere. I download it, but no idea how to use it. Would it work for getting the 1B file?
