BMW-530i 2008 Model Gulf Specs: Remote control battery discharged - Bimmerfest - BMW Forums
Old 01-19-2014, 10:53 AM
sravan1947 sravan1947 is offline
Mein Auto: BMW 530i 2008 Model
Exclamation BMW-530i 2008 Model Gulf Specs: Remote control battery discharged
Hi,
I own BMW-530i 2008 Model Gulf Specs full options, Since few days its giving warning in the dash board panel that "Remote Control Battery Discharged". I have read in another threads that for the cars which have comfort access enabled battery in the key either can be replaced or can be recharged by inserting it into key slot. I always used to insert in the key in the key slot instead of using comfort access.
My key doesnt have any slot for battery to replace it. I even tried using new unused spare key I have but even then dashboard still shows the message "Remote control battery discharged"
My Key No: BMW 6986585-03 (868 MHz)
Please help how to get rid of this warning.
Thanks,
Sravan
Old 01-20-2014, 01:21 AM
Orient325 Orient325 is offline
Mein Auto: E60 530i LCI
You can easily replace the battery in the key itself -- there is a tab on the back of it which you can remove with a coin
The battery that goes inside is similar to a calculator battery (VL2020 I think?) and should be easy to find
Current: 2009 E60 530i
Previous: 2005 E90 330i SE Individual, 1999 E39 M5, 2002 996 C4S, 2007 CLS55 AMG, 2005 E60 535d M Sport, 2003 E46 330Ci Sport, 2006 E85 Z4MR, 2002 E46 325Ci Sport, 2002 E46 320d SE
Old 01-20-2014, 01:40 AM
Hi,
My key doesn't have any opening which allow me to change the battery. Also today I used my new spare key by inserting it in key slot. But even then the dash board showed "Remote Control Battery Discharged" warning.
Please help, if anybody has similar issue.
Thanks,
Sravan
Old 01-20-2014, 01:42 AM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
If your key has a battery compartment in the back then it has CA and the battery is replaceable, if it does not have a compartment for a battery then it does not have CA.
Heres a picture:
Old 01-20-2014, 02:04 AM
Hi,
So I don't have the battery compartment in my key and I don't CA. My key look like the one on the rightside without black arrow. That's fine but then why my dash board started popping up warning message that "Remote Control Battery Discharged"? I never used CA in my car and always used to keep the key in key slot and drive. But since 2days I am getting this message all of a sudden.
Thanks,
Sravan
Old 01-20-2014, 06:59 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
If your key is as you described and you have Comfort Access, you have the wrong key. A car with CA will not charge the key. it must be replaced periodically.
Old 01-20-2014, 09:36 PM
Hi,
I don't have CA equipped in my car I can't open doors without unlocking in remote control. My key is a regular key. But what surprised me is once I started my car by keeping the key in key slot and stopped, removed key from key slot and immediately tried starting car and it started (Only once). This made me to think if I have a CA in my car. Its ok now CA is not my concern, its the warning that its popping up in dash board "Battery of remote control with integrated key discharged.
Please help.
Thanks,
Sravan
Old 01-20-2014, 09:41 PM
Old 01-20-2014, 09:47 PM
Uploading Check Control Message.
Old 01-22-2014, 06:32 AM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
Originally Posted by sravan1947 View Post
Hi,
Please help.
Thanks,
Sravan
Yes, this is possible without CA key fob. It is only good for like 10-15 seconds. So what you're needing is a new key fob. The battery is recharged in the slot but still it is only good for so long. As far as your spare key goes, if it went unused for a fair amount of time, then it too went dead from lack of recharge. The fall back of this system is what you're seeing, it won't remotely do anything but it will physically let you still start the car. So again, new fobs...sorry.
Old 01-22-2014, 10:45 PM
Hi,
Thanks for your reply. I used my spare key 2-3months back which also showing the same warning now. You mean to say that I need to change both my keys to get rid of that warning? They wont get charged while on drive (keyed in) intermittently?
Thanks,
Sravan
remote control battery
