Shocks and struts or coilovers? - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 07-20-2014, 01:39 PM
E30 Soft Top E30 Soft Top is offline
325i Convertible
Mein Auto: 1988 325i Convertible
Just as it says... what are the pros and cons of both? Thanks for the input.
Old 07-21-2014, 04:49 AM
petesi21 petesi21 is offline
Mein Auto:
great question.. And I would also like to know if the ground control top hats are also needed to properly align a lowered e30..
Old 07-21-2014, 11:34 AM
325i Convertible
And I want to know what this means lol
Old 07-22-2014, 04:36 AM
Mein Auto:
http://www.ground-control-store.com/...egory.php/CA=8 go to this link. Ground control makes suspension for the e30. They also sell camber plates to properly align the car. Not sure if it's needed or not.
Old 07-22-2014, 08:01 AM
325i Convertible
I just need to decide which route I want to go.
Old 07-22-2014, 08:09 AM
Mein Auto: '06 AW 330xi
The benefit of a coilover system is that the springs and shock/strut valving spring rates are matched to each other.
While shocks/struts alone may be valved for lowering springs, there are many different lowering springs available that offer different spring sizes and rates.
Another benefit to a coilover system is its adjustability. The most basic coilover kits offer at least ride height adjustment. As you get more advanced packages, you can adjust damper, rebound, etc in addition to height.
Camber plates are only necessary if you want to change camber on the fly. People normally install these for track use so they can quickly set more negative camber for the track. And when they get back onto the street, they can dial the camber back out so there is decent tire wear.
All BMWs from the factory do NOT have front camber adjustment. You can cheat and oval out the holes in the strut tower to move the strut hats in to gain negative camber but there is no reference to go by to see what kind of adjustment you're making. With most camber plates, there is some type of reference marked on the plate to indicate changes in camber.
Old 07-22-2014, 08:12 AM
markseven markseven is offline
an audience of One
Mein Auto: '04 325iTA
^ May I add that coil-overs allow for corner balancing as well...
Old 07-22-2014, 01:27 PM
325i Convertible
So... coil covers.
325i Convertible
*overs. Damn auto-correct
Old 07-22-2014, 03:23 PM
an audience of One
Coils if you will track the car. I would go with H&R Race and Bilstein Sport's of you want a well-balanced, fun street performance setup. Fixed camber plates too. 22mm front / 19mm rear sways of your choosing.
Old 07-22-2014, 03:42 PM
325i Convertible
Done. Thanks guys
Old 07-23-2014, 07:22 AM
Mein Auto:
Thank you.. This helps
