2011 BMW e70 X5 35i Fuel Pump Relay Location? - Bimmerfest - BMW Forums
Old 11-29-2014, 05:11 PM
bblack07 bblack07 is offline
Mein Auto: 2011 E70 X5 35i xDrive
Question 2011 BMW e70 X5 35i Fuel Pump Relay Location?
Hey everyone! This is my first post on these forums so I apologize if this is a question that has been answered. I did do several searches on this forum and all over the internet, but am unable to find a definitive answer.
I have a 2011 e70 X5 35i and am having some cold start/long crank issues on my vehicle (naturally I just purchased it used a couple days ago) and wanted to at least start with the fuel pump relay to see if that might be the issue, but all of the descriptions I am finding are indicating that the fuel pump relay is in the passenger side trunk next to the fuse panel that is back there.
I have opened up this access panel and there is simply not a relay there at all unlike some pictures I have seen would indicate. Where is the relay?
I even dropped the under dash fuse panel to see if maybe it was relocated there, but no luck.
Any help on the location of this relay would be greatly appreciated or alternate information to help diagnose the long crank issue I'm having after the vehicle sits for awhile would be great. After the long crank, and eventual ignition, I am also getting some stumbling of the engine. Once I take off or the engine warms up it goes away entirely. It seems that there is a correlation between lower exterior temps and how severe the issue come about. Cold = worse. It has to sit for at least a couple hours as well. IF I start the car shortly after turning it off it fires right up.
Checked battery and it's fine, it cranks hard, but just takes a full 5 seconds at times to start, then stumbles around a bit and sounds like crap. Really bummed to have issues like this and several others within a few days of buying the car. FYI it's at about 60k miles.
Thanks again for the help!
Old 11-30-2014, 12:14 PM
Bump on this one...anyone? Pulled a bunch of the covers off the engine last night with no luck.
Old 12-14-2014, 06:55 AM
danadstudios danadstudios is offline
Mein Auto: X5 2011 35i E70
My 2011 X5 35i was cranking longer than it should while cold. This occurred at 55,000 miles 6 mos out of warranty. It turned out to be the high pressure fuel pump, a known troubled item on models 2007-2010 with a sordid recall history (google X5 HPFP). Not sure they actually fixed the issue on 2011 models. $799 at dealer including labor.
Old 07-27-2015, 02:07 PM
LukasBMW LukasBMW is offline
Mein Auto: 2011 BMW X5 M packed
Hello.
I have the exact same problem. Can't find the fuel pump relay anywhere. Did you finally manage to find it?
Please help anyone.
Old 08-02-2015, 02:10 PM
wail wail is offline
Mein Auto:
Its in the rear fuse box
Old 08-02-2015, 02:14 PM
Mein Auto:
Remove the cover on the right side at the back of the trunk , u will find the rear fuse box , then bring the new fuel pump relay and compare with the same shape and most probably will be grey colour small box shaped
Old 08-02-2015, 11:58 PM
blueskyz089 blueskyz089 is offline
Mein Auto: 2011 X5 35i
Anyone knows the part number for the relay?
Old 08-03-2015, 09:06 AM
Asian Asian is offline
Mein Auto: 2011 BMW X5 35i
I think it might be something like this... http://www.ebay.ca/itm/Genuine-BMW-1...item35d87f3362
The part number listed here is: 16147229173
Old 08-03-2015, 01:58 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
http://www.realoem.com/bmw/enUS/partxref?q=16147229173
16147229173
Control unit for fuel pump
03/02/2009
To:
Weight:
0.150 kg
Price:
$270.47
Old 01-18-2017, 12:22 PM
Bimmer9 Bimmer9 is offline
Mein Auto: 2009 X5 35d
Same think looked all over in the back end especially next to the fuse box under the break lights where others are indicating where they found it and it's supposed to be but isn't there either. So please please if someone found the second location where it's located let us know....?
Old 01-19-2017, 07:32 AM
Bimmer9, keep in mind that this thread is talking about 35i model. Not the 35d. So the fuse panel may look different in the diesel E70s.
Also, I've noticed that the control unit for the fuel pump (16147229173) is only compatible with 2006-2010 E70s with N54 engine.
Old 07-11-2019, 11:04 PM
newnovice newnovice is offline
Mein Auto: e46 - 03 325i sedan
did this actually fix your problem?
did you use this part: 16147407513
https://www.realoem.com/bmw/enUS/par...&q=16147407513
