DIY replacing injectors of 09 X5 35D diesel? - Bimmerfest - BMW Forums
Old 08-17-2015, 09:08 PM
atrandom atrandom is offline
Mein Auto: 2009 X5 35D
Got misfire due to injector #6. The care is out of warranty. Many garages refuse to do it for me. They always charge me some bucks for checking then ask me go to dealer...
So, is there anyone have experience of replacing injectors?
Figure we need injector removal tools and BMW ICOM Diagnostic Tool to program new injectors.
Really need some instructions, Thanks anyway.
Old 08-18-2015, 03:53 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
This may illustrate why indies don't want to do injectors.
https://www.youtube.com/watch?featur...&v=H_DEetgHzKg
Search also for YT videos on the proper removal of injectors.
Old 08-18-2015, 06:53 AM
ninja_zx11 ninja_zx11 is offline
Probably damaged injector due to water leak.Last 2 injectors are prone to water damage as others have stated.
Old 08-18-2015, 07:08 AM
Yes. I know these threads before and preparing to do some prevention. But before I do, the injector is gone, still don't know if it's due to water leaking into engine bay.... new one worth 400$ around...
Old 08-18-2015, 07:23 AM
Very very informative video for me such an inexperienced owner.
Should I equip diagnose tools? sound like I would be a little dealer
Old 08-18-2015, 09:09 AM
blue dragon blue dragon is offline
Mein Auto: X5 35D
You will also need to run the calibration procedure in INPA or Rheingold if you do swap it yourself. Me personally, I would pay to get this job done
http://www.wardphotography.com/sig10.jpg
| '09 X5 35D - Work horse | '17 X1 MSport - Wife's daily | '17 - 340i MSport - My daily |
Old 08-18-2015, 10:21 AM
Seems nobody would do it except dealer. I don't mind to pay dealer this time. But if the car keeps giving me troubles every year every month. I'm dead then.
Last time I'm afraid of replacing glow plug but finally I did although the real problem is glow plug controler .....
This time, who knows. difficult task is dangerous and interesting.
here is a E90 video on how to replace injectors and program them. good reference.
Old 08-20-2015, 08:10 AM
Anyone know if this tool is capable to pull the injector for x5 35d?
Schley Products 11800 BMW Injector Puller
Old 08-20-2015, 09:12 AM
Not sure about the one you posted but this is what you need.
http://www.amazon.com/Injectors-Pull.../dp/B00K9QU64A
Old 08-20-2015, 07:23 PM
I'm curious if we really need a slide hammer so big like this?
Old 08-20-2015, 10:40 PM
ard ard is offline
Resident Curmudgeon
SO much fail here...
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 09-28-2015, 04:21 PM
So I've replaced the injector and code it successfully.
But unfortunately, it didn't work.
Anyway, I guess I've got root cause. injector wire for #6 is shorted. I've checked the resistance of #6 and #4(as comparison). #6 is 0. #4 is infinite.
Time to figure out how to replace or fix shorted harness....
Old 09-28-2015, 04:37 PM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
Check for mice chew: those little bastards are evil.
Whenever I do harness work on vehicle, I rewrap everything with this Tesa wiring loom tape -> http://amzn.com/B00EH6IZ6Y. I cut, join using soldering iron, cover the work with shrink wrap and rewrap the loom with Tesa.
Don't use regular electric tape as it just unravels.
I believe you can pull up the wiring diagrams in Rheingold...
Old 09-28-2015, 04:43 PM
how to take off injector wires in junction Box? They seems share a same socket with other wires. make me confused.
Where I can buy injector wire harness for replacement or only Injector Connector Plug for repair? Can't find them in ebay.
ID:	531587   Click image for larger version
ID:	531588   Click image for larger version
ID:	531589   Click image for larger version
ID:	531592   Click image for larger version
Old 09-28-2015, 04:51 PM
You may want to ping bawareca (not sure he's registered here too, otherwise check xoutpost) -> he's dismantling a 35d so he may have what you need. He seems also very knowledgeable to BMW electronics so he may help you with the diagram.
If Rheingold doesn't have the diagram, check here -> http://www.bmw-planet.com/diagrams/.
IF IT WAS MY CAR, I wouldn't replace the harness but simply pull a length of wire and solder it. Disassembling those connectors is mental and finding the proper pin practically impossible. But I would start choping up insulation and see where the damage is
Old 09-28-2015, 05:11 PM
Dissembling connectors in junction box is crazy. I just want to know if it's easy like 'unplug' and 'plug' issue. But I saw injector wires are mixed with others in one connector.
I'd like to cut connector near the injector so we can know which half part is bad. But I need a new connector to fix then.
And the question is, If I found the problem is on junction box side, what I do?
Old 09-28-2015, 05:17 PM
Thanks. I'll buy Tesa wiring loom tape then.
Old 09-28-2015, 06:32 PM
Also if possible try to disconnect the DDE and then check for continuity and short.
Old 09-29-2015, 07:53 AM
Update: Just take wires apart from junction box. while disconnected both from injector and junction box, #6 wires give me 0 resistance. others are 180K(connected to injectors of course).
So it's 100% bad #6 wire only.
Next question is how can I fix it without spare part..... or how I locate the exact point where is shorted?
Old 09-29-2015, 08:37 AM
Good find!!
So it means connection from DDE to the junction box is good.right? and problem is only from the junction box to the injector.
Is it possible to visually trace the wires from the junction box to the injector? I think each pair to each injector is twisted.So check if the got pinched and shorted.how long is the wire run from junction box to the injectors?Is there any connector inside the junction box to disconnect the injector wire from the DDE side of wiring?
Its also possible for the wires to get shorted right inside the connector (injector side) due to water problem.You may have to cut one or both wires from the twisted pair close to the injector connector to diagnose the location of short.
Old 09-29-2015, 08:45 AM
Or another option:
Just get the injector wiring harness for $64 from ECS tuning.
http://realoem.com/bmw/enUS/showpart...diagId=12_1201
https://www.ecstuning.com/ES1876917/
Old 09-29-2015, 10:55 AM
Good find!!
The wire should be looks like this. I pull the pic from ebay, not exactly the same but almost. box side looks like brand new so injector side is most possible.
It's going to rain so I have to do it tomorrow.
Old 09-30-2015, 11:02 AM
Wondering which slide hammer did you use to take the injector out and where did you get used injector?
Old 10-01-2015, 03:12 PM
Everything is from ebay.
Old 10-01-2015, 03:19 PM
so today I've found the shorted point. The truth is easy that at that point two lines are not is correct position, they are pushed very hard by wire locker. the skin was broken and mental part kiss each other finally.
I've fixed the wire but got a another headache. The car wont' start.
It throw out 4x4, DSC and fuel pump warring. I guess that's because I unpluged 5 sockets in junction box. Even I pluged them back, there is still something triggered.
Tried to clear error code, but 3 communication errors can't be deleted. Seems there must be some problem in junction box after I touched them.
Any suggestion?
