CCB OEM calipers test retrofit in non-CCB M3/M4 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 12-05-2015, 02:41 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Purpose: to find out what is required to fit CCB calipers in the standard steel-rotor brake system
Specs:
Iron rotors (standard):
- Front = 380mm x 30mm + 4-piston OEM Brembo calipers
- Rear = 370mm x 24mm + 2-piston OEM Brembo calipers
CCB brake kit (optional):
- Front = 400mm x 38mm + 6-piston OEM Brembo calipers
- Rear = 380mm x 28mm + 4-piston OEM Brembo calipers
Parts:
- 6- and 4-piston OEM Brembo calipers custom refinished in gloss metallic gold with painted-on racing Brembo logo and full clearcoat (from matte, non-metallic OEM gold paint) P/N 34117850463, P/N 34117850464, P/N 34217850465 and P/N 34217850466
- Front F10 M5 OEM steel rotors P/N 34112284101 and P/N 34112284102
- Front CCB rotor shield P/N 34112284767 and P/N 34112284768 (not shown)
- Centric Posi Quiet Semi-metallic front pads D1648-1
- Centric Posi Quiet Semi-mettalic rear pads D1155
- Front custom caliper bracket (not shown)
- Challenge Stainless Steel Brake Lines (not shown)
Front rotors
- First fitment problem
Right from the start, standard front steel rotors have a width difference of 8mm from the CCB rotors, which is unacceptable with the CCB calipers:
Solution - OEM F10 M5 steel rotors (400mm x 36mm):
-Second fitment problem
M5 rotors hub center diameter is smaller than M3/M4 hub diameter:
M3/M4 front hub diameter (~78.65mm)
M5 front hub diameter (~74.51mm)
M3/M4 rotor on top of M5 rotor
Solution - precision machined M5 front rotor center bore to 79mm with replica ~3mm chamfer (very important, just opening the bore to 79mm will not work, bore must have a ~3mm lip all around the edge of the bore)
Third fitment problem:
OEM brackets included with CCB calipers have a 2.5mm offset (towards the inside) difference when M5 rotors are fitted:
Solution - 2.5mm custom bracket fabricated and installed
Rear Rotors
- No fitment problems at all with OEM M3/M4 370mm rear rotor and rotor shield, 100% PnP:
Conclusion:
- Full retrofit requires minor custom front work but relatively straightforward if done by machine shop. Custom bracket fixed the negative offset of front CCB caliper with front M5 rotor. Front pads use counterweights to eliminate any vibration. Front pads are also available without counterweights. Centric pads were selected for street use (low dust, better than OEM performance). Porterfield street and racing pads are available.
Rear fitment was 100% PnP. Rear pads were selected to cover most of the gap between the pad contact area and the rotor. The rear pads that can be used for this Brembo 4-piston calipers is a 67mm D1155 pad.
Thread will be updated with performance review once fully installed.
Old 12-05-2015, 03:28 PM
nene nene is offline
Mein Auto: Audi,BMW,Jaguar,Porsche
Great work. Thanks for sharing and keeping us posted.
Old 01-05-2016, 01:30 PM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
Looks nice but is there any difference in moving to this setup?
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 01-05-2016, 02:16 PM
Technic's Avatar
Mein Auto: 2017 M3
Difference should be the same as getting an aftermarket BBK but with OEM parts and at about half the price.
Old 01-05-2016, 04:09 PM
r3zon8 r3zon8 is offline
Mein Auto: E92 M3
great work!
Old 01-08-2016, 06:03 AM
M35Z4 M35Z4 is offline
Mein Auto: German
Fantastic project, thanks for taking it on!
Old 01-23-2016, 03:53 PM
Technic's Avatar
Mein Auto: 2017 M3
Prototype bracket used with an OEM F10 M5 front caliper (OEM front calipers do not include the OEM bracket as in the F8x M3/4):
Old 01-23-2016, 03:56 PM
Mein Auto: E92 M3
nice progress man. i appreciate you sharing all this info.
are you local to south florida???
Old 01-23-2016, 03:58 PM
Technic's Avatar
Mein Auto: 2017 M3
Yes, Ft Lauderdale...
Old 03-02-2017, 06:09 AM
amstechnics amstechnics is offline
Mein Auto: m3 f80
This is a great thread... Exactly what i was looking for
Really wanted to take my rear disks upto 380mm though
Old 03-02-2017, 10:59 AM
Technic's Avatar
Mein Auto: 2017 M3
There is a kit (OEM CCB calipers + aftermarket rotors) made by Endless that include 400mm and 380mm rotors (not OEM).
BMW OEM Audio PnP integration
www.TechnicPnP.com
[email protected]
Old 03-02-2017, 11:29 AM
Technic's Avatar
Mein Auto: 2017 M3
Review:
It did not take long to realize that the braking power of this 6/4-piston + bigger front rotors retrofit is something else compared to the standard M3 4/2 piston setup. Brake feel, stopping power and overall pedal response is significantly improved. Brake modulation is still nicely balanced but with a more solid feel with less pedal pressure. After two months of use no noises, no vibrations, nothing negative to report. I used to have a full Brembo BBK in my old E92 M3 and it never felt as much as an improvement over the OEM brake setup as this retrofit. Really happy with this effort.
Note: this retrofit is using the same standard OEM brake booster for iron rotors with no coding changes as the standard 4/2-piston iron setup. No need to code/replace the booster for CCB calipers as in the OEM CCB retrofit kit as the coding is to adjust the CCB booster to the friction of the CCB rotors, which is different from the friction of the iron rotors. So no no need to code/replace the standard brake booster for iron rotors for these calipers.
www.TechnicPnP.com
[email protected]
Old 03-02-2017, 12:20 PM
Mein Auto: m3 f80
Awesome....
I'm glad your fully tried and tested it and know it works really well...
Do you have a link to where you purchased from and what did it set you back in price
Old 03-02-2017, 12:29 PM
Technic's Avatar
Mein Auto: 2017 M3
I got all the parts from forum sponsor ECS Tuning.
www.TechnicPnP.com
[email protected]
Old 03-02-2017, 12:33 PM
Mein Auto: m3 f80
What price did you pay..... just so I know what I'm going to be looking at
Old 03-02-2017, 12:35 PM
Technic's Avatar
Mein Auto: 2017 M3
I do not post prices, sorry. Check with them as prices change.
www.TechnicPnP.com
[email protected]
Old 07-27-2017, 03:17 PM
VGM6 VGM6 is offline
Mein Auto: F86 X6M, E63 M6
Thats awesome glad it worked out well for you. Is there any way to find out if the rear CCB caliper will fit on the stock rotors of an F86 X6M? It seemed like in your post the only issue you had was mounting the fronts with some custom work but how about the back? I want to use the stock rotors on my X6M with the rear caliper of the CCB but no one has done this from what Ive seen on the forums other then you. This is the part number for the rear rotors if it can help with my question. 34212284904
Thanks in advance!
V
Old 07-27-2017, 06:33 PM
Technic's Avatar
Mein Auto: 2017 M3
You will need to do your own homework as your rear brakes use an electronic parking brake (don't know if the X6M rear calipers are part of that system; no F8x has electronic parking brake), and definitely you need to measure the rear OEM caliper brackets in your M as they are going to be completely different from the M3 rear caliper brackets. You may need different brake pads as well...
Thanks in advance!
V
www.TechnicPnP.com
[email protected]
Old 09-26-2018, 01:35 PM
erik-f80 erik-f80 is offline
Mein Auto:
What kind of Brake pads else i can use? Im from germany and it is quiet difficult to get the Centric brake pads.
You write that the centric Pads are better than the OEM Performance Pads. Which Performance Pads i can use for this caliper? Of the BMW F10 M5?
Old 09-27-2018, 01:07 AM
Technic's Avatar
Mein Auto: 2017 M3
Any pads with these backing plate shapes:
Front pads D1648-1
Rear pads D1155
For example, Hawk HPS in D1648-1 for F10 M5 iron rotors, which is the same front pad for the front CCB calipers. The D1155 rear pads are for Ferrari and Corvette rear Brembo calipers. Check with your brake pad manufacturer about these shapes.
www.TechnicPnP.com
[email protected]
Old 03-18-2019, 02:06 PM
ruben_17non ruben_17non is offline
Mein Auto: Bmw E92 LCi / Bmw X4
380x30 m3 rotor have same offset as 370x30 from f30?
or, anyone can check or say me offset of original rotor of m2/3/4?
i need "D" Measure (image is just example)
