Thermostat recall - Bimmerfest - BMW Forums
Old 01-17-2016, 10:16 AM
pdxway's Avatar
pdxway pdxway is offline
Mein Auto: 2013 328i
Thermostat recall
I have 2013 328i and got thermostat recall done yesterday while doing my scheduled oil change. I googled it and only seen this recall mentioned for 5 series last year, but did not see anything so far for 328i. SA did not explain much other than it is not a must do. Anyone have more details?
Old 01-17-2016, 02:06 PM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
Haven't heard about a "recall" on the thermostat but ours triggered the CEL a couple months ago and the part was back ordered for a couple weeks. Apparently a defective thermostat affecting a number of the earlier F3x's, it was not routing the correct coolant temperature into the engine hence the CEL. The car ran normal - just had to look at that alert light for a few weeks.
Dan
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSpt AlpWhite
Old 01-17-2016, 02:09 PM
pdxway's Avatar
Good to know. Hopefully it is not something the could hurt the car. Thanks!
Old 01-17-2016, 04:46 PM
Eagle11's Avatar
Eagle11 Eagle11 is offline
Mein Auto: 2017 330i
Mine was replaced last year and took the dealer about 2 weeks to get the part, which I found very odd.
2017 330i, 475, KCL3, ZDA, ZPP, 2A5, 494, 4GA, 609, 6CP BMS JB tune and Many Coded goodies
2016 328xi GT, A86, LCOM, ZDA, ZDH, ZLP, ZPP, ZTP, 494, 5AC, 5DF, 5DL, BMS Stage 1, Many coded goodies. ED 8-28-2015 Gone
Old 01-17-2016, 04:53 PM
namelessman namelessman is offline
Mein Auto: bimmer
To OP, is there a SIB to this fix?
Old 01-17-2016, 05:18 PM
tturedraider's Avatar
Freedom isn't free!!
No recall listed on NHTSA, but this SIB is there -
Service Bulletin No.: SIB-12-33-14
Component(s): ENGINE AND ENGINE COOLING
NHTSA ID Number: 10058476
All Products Associated with this Service Bulletin
Vehicle MakeModelModel Year(s)
BMW 3-SERIES 2012-2013
BMW X3 2013-2015
BMW X4 2015
0 Associated Documents
Manufacturer: BMW of North America, LLC
SUMMARY:
BMW: DUE TO TRANSMISSION OIL HEAT EXCHANGER'S FAULTY THERMOSTAT OR ENGINE FAULTY CHARACTERISTIC MAP THERMOSTAT, ENGINE COOLANT FAILS TO REACH OPERATING TEMPERATURE, WITH LOW HEAT OUTPUT AND SERVICE ENGINE SOON LIGHT COMES ON. NO MODEL YEARS LISTED. *PE
www.bmwcca.org
Old 01-17-2016, 05:21 PM
Mein Auto: bimmer
Thanks, looks like time to check if key data shows any campaign.
Old 01-17-2016, 07:21 PM
sean.miamiheat sean.miamiheat is offline
Mein Auto: 2014 328i Luxury Line
My SEL light came on about a year ago. Turns out it was the thermostat. It got replaced within 2 days and everything is going smoothly. Car is a MY2014 328i.
Old 01-17-2016, 08:51 PM
fg9ze fg9ze is offline
Mein Auto: 2013 135is
My CEL came on last week. It ended up being the thermostat as well. Part has been ordered and will be replaced when it arrives.
Old 01-18-2016, 10:01 AM
pdxway's Avatar
It looks like the SIB in my case is newer. The SIB for my work is SIB 11 10 15
Old 01-18-2016, 05:29 PM
Scottaw Scottaw is offline
Mein Auto: X3 28i
Wish I knew about this the three times I tried to get the dealer to fix the lack of heat on my 2014 X3. That was one of the main reasons I traded it in, hated freezing my ass off in the winter. Second reason was a leaky sunroof that would create mold and stink on sunny days after rainy days. Enjoying a F31 now at least. Heat works great, sunroof doesn't leak/smell, and it corners and rides much nicer!
Old 01-18-2016, 06:50 PM
Mein Auto: bimmer
Yes mine has SIB 11 10 15 pending as well from latest key read.
Old 01-18-2016, 06:52 PM
Mein Auto: bimmer
The thermostat in this SIB seems to be for engine coolant temperature instead of cabin ambient temperature.
Old 02-22-2016, 09:47 AM
Jlarrea Jlarrea is offline
Wasn't aware of the issue until I took my '14 F30 in for annual service. SA indicated they would take care of it provided the part was in stock (which it was)...apparently back-ordered from Germany.
I assume this was the engine thermostat as the work order indicates antifreeze/coolant was added.
Old 06-04-2016, 03:57 PM
mchattod mchattod is offline
Mein Auto: Everything
I got a CEL. BT tool shows 1D2401 Map Thermostat, activation, short circuit to B+. Sounds like I have a bad thermostat. Does anyone know if this SIB is a recall? I'm outside my factory warranty at 59K miles.
Thanks,
Dan
2013 328i, Sport Line
Old 06-04-2016, 11:09 PM
Mein Auto: bimmer
Thanks,
Dan
Yes the thermostat SIB is a technical campaign, just ask the SA to read your key to check.
Old 06-04-2016, 11:24 PM
donsbabybeamer donsbabybeamer is offline
Mein Auto: 2014 X1 28I X-line
Had my regular service done 3 weeks ago, dealer changed the thermostat on the recall. Complete service took an hour with T-stat change.
Old 11-09-2016, 11:21 AM
Daceptak0n Daceptak0n is offline
Mein Auto: '16 X5 M-Sport
I have a 2014 and just got the check engine light and engine was stalling a few times between gear changes. I put it into Sport and it went away but then came on a few minutes after. Switched back to Comfort and the stalling went away but the light is still on...
Any ideas?
Old 11-10-2016, 03:54 AM
DTRJ DTRJ is offline
Registered User since 07
Mein Auto: 2020 X4 M40I
Took our 2014 328 in for normal annual service. They changed the thermostat as well saying their was a service bulletin requiring it, also added antifreeze NO CEL SEEN
Old 01-14-2017, 02:27 PM
imtjm imtjm is offline
Mein Auto: 328ix sdn; M240ix cpe
BMW NA has issued an Extended Life Warranty (ELW) on the thermostat. You can check your vehicle at bmw-rp.com to see if your car is included, or ask your dealership to pull a key report which will show all BMW NA issued ELW for your vehicle. Of note, my 2013 also showed an ELW for the N20 Leak Diagnosis Module (NVLD), too.
Old 01-17-2018, 02:27 PM
mr_clueless mr_clueless is offline
Mein Auto: 2019 RDX
I just got a letter today for my car (MY2015 328i).
Old 01-17-2018, 03:54 PM
Al Bundy Al Bundy is offline
Mein Auto: 2009 E90 328xi MT
Ironically...or is it expectedly...my thermostat went out on my 2015 335ix on Monday. 27k miles on the car.
https://www.bimmerfest.com/forums/image.php?type=sigpic&userid=344578&dateline=1376485586
CURRENT
2015 F30 335i xDrive MT - Melbourne Red - Black Dakota Leather - M Sport - Cold Weather Package - Dynamic Handling Package - Lighting Package
RETIRED
2009 E90 328i xDrive MT - Tasman Green - Oyster Dakota Leather - Premium Package - Navigation w/ IDrive - Cold Weather Package - Park Distance Control
Old 01-17-2018, 03:59 PM
Mein Auto: 2019 RDX
Have 3 parts with extended warranty now:
- Coolant thermostat 10 yr/120K
- Fuel tank leak diagnostic module 10 yr/120K
- Timing chain 7 yr/70K
