F45/F46/F48/F55/F56 Coding Thread - Bimmerfest - BMW Forums
Old 01-18-2016, 08:50 AM
n3xT n3xT is offline
Mein Auto: Bmw 218d GT
Hello,
i propose to open One master threads to regroup the information about the coding of theses car as they have the same architecture .
i already found a coding sheat for mini :
https://docs.google.com/spreadsheets...bnw/edit#gid=0
and i've already VO code the 6NS option to my car with this procedure !
1) Just Add 6NS to FA and VO Code HU_ENTRYNAV
2) You will not get Voice Control without an FSC Code, but you can still code EBT.
3) No. Just add 6NS to FA, Save FA, Load FA in Coding Module, Activate FA, and VO Code HU_ENTRYNAV.
owners of F45/F46/F48/F55/F56 any stuff we can share, we can do it here.
READ IMPORTANT NOTES:
1) NEVER click "Code Default Values" it can reset important stuff and car might not start and need to get towed to the dealer to fix the software
2) Make sure you click "Code FDL" and not "Code" (clicking code will reset the car to the factory setting erasing all the FDL coding for the selected ECU)
3) Always code with the car running or with a commercial grade charger connected to it, else voltage might drop during coding and you could get unexpected errors. (if you are codding the DME ECU you can't have the car running so you will need a charger)
4) Launcher note: E-Sys Launcher Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT create .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future."
What's Needed for coding?
Enet Cable search on ebay http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
E-sys software (ask here https://www.bimmerfest.com/forums/sho...38188&page=121)
NEW: Free universal token option https://www.bimmerfest.com/forums/sho...d.php?t=805745
NCD CAFD tool https://www.bimmerfest.com/forums/sho...d.php?t=749668
Whatever you do never ever ever press "Code Default Values" ... you have been warned :-)
Coding 101 video
How to VO code
Connect => Read FA => Activate FA => Read SVT (VCM) => Right-Click on ECU you want to code i.e. HU_NBT (the ECU itself not the underlying CAFD) => Select CODE.
Corrupted CAFD
Just inject new CAFD into ECU, and VO Code it.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Read I-Level
To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps
Targets:
F001 psdzdata covers the F01/F02/F03/F04/F07 (5-Series GT is an F07 NOT an F10)
F010 psdzdata covers the F06/F10/F11/F12/F13/F18
F020 psdzdata covers the F20/F21/F22/F23/F30/F31/F32/F33/F34/F35/F36/F80/F82/F83 (There is no Z4 F-chassis yet)
F025 psdzdata covers the F15/F16/F25/F26/F48/F85/F86
F056 psdzdata covers the F45/F46/F48(BMW)F64/F55 F56 (Cooper Mini's)
I001 psdzdata covers the i3/i8
File Type: pdf FA (VO) Step-By-Step (MWPos) 8-24-2013.pdf (1.05 MB, 1772 views)
File Type: pdf 141121 List of abbreviations and modules.pdf (44.5 KB, 1731 views)
Old 01-29-2016, 06:16 AM
horsti82 horsti82 is offline
Mein Auto: F46
Hey there,
iīm new in this Forum and firstly want to HELLO
Iīm from Germany, so if my grammar suckīs dont`be angry with me
Iīm new in car coding, but have "some" knowledge in hacking etc, so it was easy for me to read me in.
Here are some parts, i coded till now:
ACSM2
3001 seatbeltreminder_Fahrer nicht aktiv
3001 seatbeltreminder_Beifahrer nicht aktiv
For windows that they close when it rains
HU_ENTRYNAV
3000 REGEN_SCHLIESSEN --> there was no opportunity to test till now, if it works
For working USB video playback
HU_ENTRYNAV
3000 ENT_VIDEO aktiv
3000 ENT_MC_VIDEO_SUPPORT aktiv
3000 SPEEDLOCK_X_KMH_MIN FF
3000 SPEEDLOCK_X_KMH_MAX FF
3003 OGG_CODEC_ON_OFF aktiv
3003 API_USB_VIDEO first -> because only one USB Port
3003 API_IPOD_VIDEO first
3003 API_USB_READ_WRITE aktiv
3000 ENT_CODEC_OGG aktiv
3000 ENT_CODEC_XVID aktiv
3000 ENT_CODEC_VCD aktiv
(Coded it, but couldnīt get it work. Only hear the sound and have no picture. Maybe someone else could try)
WLAN
HU_ENTRYNAV
3000 ENT_MC_WLAN_STREAM_DMP_COVERART aktiv
3000 ENT_MC_WLAN_STREAM_DMP_VIDEO aktiv
3000 ENT_MC_WLAN_STREAM_DMP aktiv
3003 WLAN_MODUS both
3003 WLAN_DIAGNOSE aktiv
3003 WLAN_STATUS aktiv
(Wlan shows up in the setting, but canīt activate it. I think there is no wlan-modul build in. I thought i read somewhere that it comes with the BT modul. Maybe iīm wrong)
Ringtone from smartphone in the car
HU_ENTRYNAV
3003 INBAND_RINGIN aktiv
(Donīt work for me, but iīm using Samsung phone, it comunicates not as good as with iphone. Maybe with iphone it will work. Someone need to try it)
Triffic jam assist to 99 km/h --> be careful, it isnīt mph
SAS
3000 LDM_QalcgRel_v_Tacho_aktiv_kmh 63 (Hex-Wert)
Traffic jam assist everywhere, not only on Highway
3000 LDM_STA_Einschraenkung keine einschraenkung
Driving assist from 140 kmh to 180 kmh and you can activate it from 35 kmh
SAS
3000 LDM_WUNSCHGESCHW_ACC_max_kmh 180
3000 LDM_QalcgRel_v_Tacho_aktiv_low_kmh 55 35
Deactivate some Speedlockīs
HU_ENTRYNAV
3000 SL06_IBA_1 nicht aktiv
3000 SL07_IBA 2 nicht aktiv
(canīt find a change, so donīt know which speedlock is deactivated)
Navigation road preview
HU_ENTRYNAV
3000 NAVI_ROAD_PREVIEW aktiv
(Donīt work for me)
That all. I think itīs enough for the first post
This weekend, iīll do more coding testīs. Iīll let know know the result.
Everyone happy coding
Edit: forgot a important thing, my car is a F46 218i with Navigation Plus (6NS)
Old 02-01-2016, 01:14 AM
Thieutje Thieutje is offline
Mein Auto: BMW X1 2.5d xdrive M
Hello,
Thanks for starting up this thread.
I have my new X1 F48 2.5d since begin january.
I've tried to code the beep when locking the car but it's not working :
alarm beep when (un)locking car (you need FZD module = 302 option):
HU_NBT > 3000 > ACOUSTICAL_LOCK_CONFIRM : aktiv
I changed this, i checked again later, it's on activ but still does not work
I'm new to coding but i followed all the beginner steps so i have no clue what i did wrong
Old 02-01-2016, 01:56 AM
hello,
i found this on another forum..
could help!
With the the following settings I get 1 beep on lock and NO BEEPs on unlock:-
HU_CIC -> 3000 ACOUSTICAL_LOCK_CONFIRM = aktiv
But make sure the tick box in idrive is not ticked!!!!!!!
then I set:-
Akkustische Quittierung Schaerfen = aktiv
Akkustische Quittierung Schaerfen mit Klappenbeachtung = nicht aktiv
Akkustische Quittierung Entschaerfen = nicht aktiv
After a bit more playing around and reading one of shawnsheridans posts the meaning of the settings dawned on me
Akkustische Quittierung Schaerfen = Acoustic acknowledgment when Arming regardless of the door status
Akkustische Quittierung Schaerfen mit Klappenbeachtung = Acoustic acknowledgment of Arming depends on the door status
I think "door status" here means whether the i-drive box is ticked or not. So unticking it manages to turn off the two beeps some of us don't want.
But the mystery remains as to why
Akkustische Quittierung Entschaerfen = Acoustic acknowledgment when Disarming gives the two beeps even when set to nicht_aktiv !!!
So if I tick the i-drive box the two annoying unlock beeps come back.
Old 02-01-2016, 06:22 AM
Thanks, will try that.
I was also curious about 2 things.
Is it possible to code the distance of the driving assistant plus? the red bars in the display, i would like to adjust the distances to the car in front of me
Old 02-01-2016, 07:11 AM
I don't know for the the DAS plus.. i don't have on mine..
Old 02-01-2016, 09:50 AM
Also, ASD: Active Sound Design is present in the B46 petrol engine so i think it should also be present in the B47 diesel engine.
I was looking in the CAF files but can"t find it although it should be there.
If it is i would love to code a nicer sound like the one from the 550d.
Found alot of coding info already on how to code it but not for the F47.
In the attachment i found the ASD info (which confirms it's presence although i don't know if that also means the asd module is present or it's rather a ASD compatibility) about the B46 petrol engine but i can't find the engine.pdf about the B47 diesel engine
Old 02-02-2016, 12:02 PM
Mein Auto: F46
Originally Posted by Thieutje View Post
Hello,
It looks like you can configure the beep in FZD Modul
Old 02-04-2016, 12:52 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
Just a few sentences to the "Code Default values" in the important notes. I cannot count how much "coe default values" problems I solved in the last years. Not only one car had to be towed to dealership. If you know how you can solve it easily. Some ECUs are a little bit tricky (CID for example) and you have to flash them, but it's not a problem at all. What you can destroy with a notebook you can repair with a notebook. Okay, don't throw the notebook through your windshield.
CU Oliver
BMW G20 330e in tansanit 2 blue, all in )
Jaguar XK8 4.2 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 02-04-2016, 07:31 AM
Mein Auto: F46
Originally Posted by milkyway View Post
Hello!
CU Oliver
Thx for these soothing words
Old 02-04-2016, 11:34 PM
Originally Posted by n3xT View Post
hello,
could help!
I don't understand what it means, 'thick the idrive box'.
Can't get the acoustic lock confirm to work. All set to activ. Still not working.
Old 02-07-2016, 02:15 PM
Mein Auto: F46
When you set:
Then you have a new entry in your IDrive. You find it under:
Settings / Doors (or something like that)
There you can activate/deactivate the lock signal. Thatīs what they mean with tick the idrive box.
Old 02-09-2016, 10:05 AM
mekatu mekatu is offline
Mein Auto: 2015 F45 active Tourer
Hi ,
I am planning to retrofit cruise control to my 218i AT. I have just ordered the switch with cruise control (BMW part no: 61-31-9-263-551) and will try to install the switch and code accordingly.
However, I do not know how to easily remove the airbag from the steering wheel. (the sport steering wheel is I guess a new type used in new BMWs, different from F30 and F20)
To be honest, I am also a beginner for the coding part, I rely on the below guidance which I found for F20 and F30 and assuming it would be same for my car.
Any help would be very much appreciated on airbag removal and coding.
Coding:
Before you do this coding you must already know how to do coding, please search Google
on how to do or where to get the esys software/cable. I only let you know the step and ECU to do
FA coding
FA Coding:
1. Launch esys and connect to your car
2. Select expert mode
3. Read and activate FA (add option 544)
4. Read SVT
5. Select and code the following ECU
a. FEM
b. ICM
c. KOMBI
6. If you want "LIM" function, you will need to do FDL coding per the table below. This will
allow "SET" button to act like "LIM" button so that you get both LIM and Cruise control
functions.
CAFD_00000760-007-000-026 KOMBI 3003 SLD_ENABLE aktiv
CAFD_0000067B_002_003_139 ICMQ 3000 C_SLD_Funktion aktiv
CAFD_0000067B_002_003_139 ICMQ 3000 C_Umschaltung_ACC_DCC > zugelassen
Old 02-27-2016, 01:50 PM
Hi All,
Recieved my cable and cruise control switch today for my 2014 Nov- F45 Active Tourer. Installed the steering wheel switch without any problem.
But while coding;
Added the 544 in SALAPA Element, Saved Changes, Calculated FA, Saved the new FA, Loaded the saved FA and calculated the FA again, wrote FA FP.
Then Read and Activated FA and Read ECU (Read SVT gives error message therefore I used Read ECU) in order to VO Code Kombi, FEM and ICM.
However I could not find KOMBI, FEM and ICM. Therefore Selected each ECU under the tree and coded all of them. (I received one error message due to coding DME ECU while engine is on, but fixed it later)
There is no warning light on the dashboard now, but the retrofitted Cruise Control does not work. LIM button is still working on the other hand.
Any idea what is going on and what I messed up?
Here are the ECUs under SVT tree: ACSM2(1),BDC_BODY(40),BDC_GW(10),BKOMBI(60),DME_BA C(12),DSC2(29),EGS(18),EPS(30),FLE(43),FLE(44),FZD (56),HKFM(d),HU_ENTRYNAV(63),ICAM2(6),IHKA3(78),PM A2(2c),TCB(61),ZBE3(67)
I-step : F056-15-11-505
E-Sys ver 3.27.1 (build 44813) , PSdZ data ver. 5.01.02-2015-08-12T Extracted from ISTA-P version 3.57.3.002
Old 02-27-2016, 06:11 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by mekatu View Post
...However I could not find KOMBI, FEM and ICM
In your car:
KOMBI = BKOMBI
FEM and ICM = BDC_BDOY
I have no idea why your Cruise Control does not work though.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 02-28-2016, 07:42 AM
Thanks Shawn,
So, if I have VO coded all ECUs, is there a difference between coding BKOMBI +BDC_BODY only and coding all ECUs?
Can there be another setting needs to be FDL coded?
Here is the picture showing my SALAPA elements. Anything wrong here?
Old 02-28-2016, 09:03 AM
Thanks Shawn,
If you VO Coded every module with updated FA, you got it covered.
If it is not working, I have no idea why. I know nothing about Cruise Control in F45 Active Tourer.
Old 02-29-2016, 02:56 PM
siriuszero siriuszero is offline
Mein Auto: 2015 MINI F55
A quick look on RealOEM shows that the Cooper SD does indeed have a ASD module (though I believe you also need to have Driving Modes equipped), but the only thing you can really do to alter it, is to turn it off. You can visually check for one yourself too. If you open the hatch, pry off the left panel in the trunk and you can see the module there, if you have it. It will be silver, squareish, and have fins and a wide wiring harness coming out of it. Picture: http://www.realoem.com/bmw/enUS/show...diagId=65_2596
As far as I know, there is no way to change the ASD sounds on MINIs and I assume the reason why is that the ASD modules used are different than the ones used on BMWs. Even on BMWs, you can't make a 2 series sound like a 5 series because the modules are different, but you can make it sound like a M235i.
Old 03-01-2016, 01:29 AM
milkyway's Avatar
Mein Auto: F10 M5
Hi All,
But while coding;
Hello!
Retrofitting of SA 544 is depending of your installed cluster. There are two different Bkombis on the market, a normal one and one with the option for 544. It's the same like F20/F30. If you want to retrofit 544 you have to check the serial number of your cluster and it could be that you have to change it.
CU Oliver
Old 03-01-2016, 08:02 AM
Thanks for this. How can I check the serial number of the cluster then?
Old 03-18-2016, 02:14 AM
F45/F46 ncd files
My cruise control retrofit still not working.
Anyone in the forum owns F45 or F46 with the cruise control (544) option who can share the ncd files so that I can compare those with mine to see what is missing on my F45?
Thanks in advance.
Old 03-23-2016, 11:56 PM
DIY Guide - Retrofitting cruise control on F45/F46
Finally solved my problem and completed cruise control coding. Knowing that information on F45 and F46 is limited on the web I have prepared a DIY Guide for those who want to install the dynamic cruise control on their F45/F46.
Here is the link:
https://www.dropbox.com/s/fln6jgy54m..._Rev0.pdf?dl=0
Old 04-22-2016, 06:40 AM
fjsato fjsato is offline
Mein Auto: Mini Cooper JCW F56 Moon
Does anyone have the code to allow the glass to continue rising even after turning off the car and open the door?
Mini Cooper S 2010 R56 Volcanic Red
Mini Cooper S 2016 F56 Eletric Blue
Mini Cooper JCW 2018 F56 Moonwalker Gray
Edit: I found. Already tested:
F56:
• BDC_BODY [40] [2A85027]
9675; 3050 PwClient, 13
FH_TUERAUF_STOP_MAUT
Old 04-24-2016, 05:43 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by fjsato
• BDC_BODY [40]
PwClient, 13 FH_TUERAUF_STOP_MAUT
I am guessing you do not need FH_TUERAUF_STOP_MAUT_REAR.
