M90 Eaton supercharged E36 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-16-2016, 03:47 PM
Greenday694's Avatar
Greenday694 Greenday694 is offline
Mein Auto: 93 BMW 325is
( tight budget and very little time)
Old 04-16-2016, 03:57 PM
]First thing I bought was the supercharger off of a 93 Thunderbird SC. I cleaned it up rebuild it and then I made the adapter plate to Bolt the BMW throttle body on to the inlet of the supercharger in the back. I used 3 pieces of 1/4" aluminum plate that I drilled cut and filed to get a smooth transition from the round throttle body to the rectangular intake Port of the supercharger. Don't Shoot Me , but I then cut the intake manifold runners. I heated of the ends up with a heat gun so I can round them out to clamp on the 2" ID silicone hose. The plentum I made out of 2"x 2" x1.5" copper T's and one 2" to 1-1/2" 90-degree elbow. I cut them down and used short pieces of 2 " tubing to solder it together. The bottom of the supercharger I drilled and tapped two 1/2" holes in the intake port. One is for the idle speed control. The other for the power brake booster and fuel pressure regulator. Supercharger mounting bracket is 3/8 plate steel. The bottom bolts to the 2 bolts on the power steering pump then steps back and up to the upper alternator Bolt. And I ground down the back of the idler pulley. Then I bent it back to form the supercharger platform. I use 1" wide flat Steel to run a horizontal brace from the back of the platform to the engine and a vertical brace down to one of the original intake manifold support mount. The front of the bracket I cut out to clear the original belt tensioner and a large round opening for airflow to the front of the alternator. The supercharger is driven by the second pulley that I mounted on to the front of the power steering pump. There was no room or place for a tensioner pulley so I have to use spacers under the supercharger to put tension on the Belt. The output of the supercharger runs down to the front of the car into the intercooler below the front bumper out of the other side back crossed underneath of the radiator up over top of the supercharger pulley and into the intake manifold. I put a chip in the DME that has a more aggressive ignition and injector curve. That seems to work pretty good. Plus it deletes the speed governor and raises the rev limiter to 7400. Even though the power starts to drop off at 6500. It is a lot of fun up to that point.
ID:	559424   Click image for larger version
ID:	559425   Click image for larger version
ID:	559426   Click image for larger version
Old 04-16-2016, 05:38 PM
olivers_bmw olivers_bmw is offline
NCC BMWCCA member
Mein Auto: E36 and e34
Interesting project, what do you figure you you have into it and how hard was it to fab up the other parts. Did you use a template or eyeball it.
Old 04-16-2016, 05:59 PM
I would have to say around $800 so far. I use the old rule measure twice and cut once. I already had a good idea of what I wanted. But working in such a small space did make it very difficult. And I couldn't find any others that I could copy some from. I still have to relocate the power steering reservoir. Right now if I had to add fluid to it I would have to remove the supercharger to get to it. LOL
Old 04-16-2016, 06:50 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Very interesting. Drivinfaster is planning something very similar.
Do us a favor....please don't use 2 for "to" and 4 in place of "for". That got real difficult to read since you had 2" dimensions in there along with "2" and "4".
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 04-16-2016, 07:01 PM
Point taken. I'm still having some problems with idling after coming down off of the Boost. My best guess so far is that with all of the tubing and intercooler dropping down into 20 + square inches of vacuum that by the time the idle speed control tries to compensate for the low idle the engine has already stalled. I can manually turn the idle up and it will not stall. But I have to turn it up to about 1000 rpms. And I don't like to do things that way.
Old 04-17-2016, 05:58 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
very interesting fab. i considered the m90 from the 3.8 supercharged fords but found none available in the salvage yards. settled for an early m62 eaton from gm. much wider base and has a portion of inlet on the housing.
initial plans were to throw it on the m50 in cadence but that fell through rather quickly. it is on the back burner as of right now since i have so many other things going on and am looking for another house with a garage to be able to tinker more.
current plans for the supercharger are now moving toward the m42 in piper, my 97 vert. i have a little bit more room to fab up stuff and am planning on using the tensioner from the gm 3800 instead of shims.
not sure if i am going to try to run it like an off the shelf sc with an intercooler or run it directly into itb's and add meth injection. again so many plans and stuff happening (i think some people call it "life"...) that these plans and ideas all get pushed back.
thanks for sharing, though.
and yeah, that ps reservoir is going to need to be relocated for sure., again, a little more room in the m4x engine bays than the m5x.
df
Old 04-17-2016, 06:27 AM
I do hear what you are saying. I work over 60 hours a week and try to have a life at the same time. I bought the supercharger 9 months ago and little by little have been fabricating everything to put it on my car. When I blew 2nd gear out of my getrag 5-speed and my Vanos was acting up 3 weeks ago I figured that was the perfect time to put the supercharger on too. As for throttle body location , I chose to run it up stream because friends of mine have have tried running it Downstream on the M90 and the larger m 112 with air-to-air intercooler. The problem they ran into was when they let off of the throttle at higher RPMs and boost there would be a boost surge up against the throttle plate and we blow the hoses off. They didn't know how much boost but it did Peg the Gage. One of them even bent the throttle plate. Eaton's are Roots type positive displacement superchargers and as long as they have unrestricted airflow in they will blow air out. Good luck with your build , I would love to see how it turns out.
Old 04-17-2016, 06:37 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
What tuning?
Turbo Build Here
Old 04-17-2016, 07:09 AM
Right now it's a stock Motronic 3.1.1 with a AC SCHNITZER chip. It seems to work pretty good. It's a little Rich at low RPMs. I used a friend of mine's gas analyzer. And did the old school method Running chop plugs. I checked the plugs at 2500 , 4000 and 6200 RPM. They we're a little on the rich side of perfect.
Old 04-17-2016, 12:43 PM
not sure how ford handles their decel from boost transition, but the gm unit has a bypass valve that is vacuum/boost controlled to reduce backpressures on the throttle plate.
also not sure what you mean by upstream/downstream on the throttle plate....
regardless, i have seen multiple configurations of the eaton variants used remotely with a plate to fit the intake plumbing. i do not really wish to run lots of plumbing all over the place, even if i do have ample space in the m42 engine bay, so will probably look to add a meth kit.
df
Old 04-17-2016, 02:00 PM
Upstream means that the throttle body is before the supercharger on the intake port. Downstream means that the throttle body is after the supercharger. Ford and GM both run Upstream setup putting the throttle body on the intake of the supercharger. So that way they don't have to worry about blowing gaskets and any other parts. The bypass valve is used on both to reroute the output of the supercharger back into the intake if the boost starts to go to high. And it means that they can make the Boost come on sooner with the right pulley setup and still not go over to the point of causing damage to the engine. The other advantage to running the throttle body Upstream of the supercharger is that at Cruise speed restricting the flow of air into the supercharger which cut back on the parasitic drag. Roots type superchargers spin very easy when they are under vacuum. One of the main drawbacks of these superchargers is that they heat the air by compressing it. Not as much as a turbo would. But anytime you heat up the air molecules they expand and this is counterproductive to what you're trying to achieve with forced induction. The running an intercooler with an Eaton is not much of an option it's kind of a necessity.
But before I did any of this. I upgraded the brakes. Installed Bilstein shocks and struts , 18 inch staggered wheels with 255 35 in the back and 235 40 in the front . A short throw shifter and stage 2 clutch with a single Mass lightened chromoly flywheel. And to cut back on gear chatter I'm using a 50/50 mix of red line D4 and 75 140 synthetic gear oil in the transmission. Polyurethane rear subframe mounts. New lower control arms front and rear. Tie rod ends. Sway bar mounts and links. And because I did all this myself , I started to learn how to curse in German. LOL even though I have over 20 years experience as an auto tech. The next step is the car is going to the body shop because I am lousy at body work. They are putting on the M3 side skirts bumper cover and rear diffuser. Then painting it cobalt blue firemist.
My baby is a 93 325is. With an M50b25tu engine.
Old 08-25-2016, 05:22 AM
Just a quick update , I did have to go up to 24 lb. injectors. I realize that the stock injectors were pretty much maxed out at higher RPMs and the fuel wasn't atomizing properly.
Old 11-26-2016, 04:24 PM
I'm back with another update. I'm still pulling my hair out trying to get the tune right on this engine. And I thought fabricating everything to put this supercharger on was going to be the hard part. This Bosch motronic really does not like a positive displacement blower. It is fighting me every step of the way. And since I can't afford 3000 for a good stand alone I'm going to try fic 6 piggyback. Don't get me wrong it does run pretty good but it's still not right. A little Rich download and it starts to lean out up-top. If I want it hard I turn the fuel pressure up. But then the idle is really rough and will stall. But at least I won't cook anything at 7400 RPMs. And the mid-range is so sweet :-). I don't know how I ever drove any car without forced induction. But I will keep updating. So maybe others can learn from my mistakes.
Old 11-26-2016, 04:26 PM
Still need work
Old 11-26-2016, 04:27 PM
Here too
Old 11-26-2016, 04:40 PM
I definitely want to thank everybody on the Forum. I've read a lot on here and learned a lot. And I'm still learning
Old 12-02-2016, 10:49 AM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
I find this awesome! A friend and I are doing the same! I have the hardship of using the m90 with the longer snout, so it sits back another few inches. But would like to see more pics of the guts!
I plan on starting around a 5lb boost at first which doesnt need a cooler or tune. But I also have all the other na mods, so hopping for 275 at the wheels! Thanks for the coolness!
Old 12-02-2016, 12:42 PM
Thanks for your reply. I'm glad to see somebody else doing it too. These M50 Motors are definitely tough. Mine has 247000 miles on it. And nothing's been touched internally. I bought it from the original owner. And after nine thousand miles with the supercharger the compression is still 180 to 190 across the board. But even at 6 pounds of boost I had problems with getting the tune right. The Bosch motronic with mass air flow sensor and no map sensor is really hard to make them run right when boosted. Stock tune stock injectors we're okay up to about 4000 RPMs. Then after that it started to get dangerously lean. Even with a boost referenced fuel pressure regulator and turning the pressure up. So I put in 24 pound injectors. But that started all the fun I'm trying to get it to run right again. The DME was trying to fuel like it had 17 pound injectors. I went back and forth for months with a tuner trying to get it right. He got it close. I just installed an AEM pic6. So far that is doing the trick. The big Advantage is that it has a built-in map sensor so I can add fuel under boost and leave idle and cruising set to stock. Bad part is that for some reason it won't let me interface with the timing. The pic6 doesn't like my crank position sensor. Other than that I like it. Oh and before I forget. Using a turbo intercooler kit will work but the problem is running this type of supercharger means that all of the piping drops under vacuum. And what happens is those silicone hoses will get sucked shut. So I tried to keep them as short as possible. The longer ones like the 90-degree coming out of the supercharger I put one of those metal Springs from a radiator hose inside to keep it from collapsing. Good luck and I would love to see pictures :-)
Old 12-02-2016, 12:45 PM
Here's some old ones and new ones.
ID:	583303   Click image for larger version
ID:	583304   Click image for larger version
ID:	583305   Click image for larger version
ID:	583306   Click image for larger version
Old 12-02-2016, 02:47 PM
Screamin demon
From my friends experiments a stock dme will take up to 5lbs without needing extra goodies. But I am not sure if that is considering the m50b30 or not and how it will effect it. Plus I am obdl. So that might make this a bag or worms.
Where did you get that plate?
Old 12-02-2016, 03:00 PM
Lol.. That my next step. I have the whole bottom end from a M54b30, to put in my M50b25tu block next spring.. I made the plate, with a little help from a local metal shop. And the adapter for the TB.
Old 12-03-2016, 03:45 AM
Screamin demon
I have a custom 60mm itb setup Im making for the project out of VW 1.8 l throttle bodies. I work at a foundery so I had a intake cast, up to about the same spot you cut yours off, out of aluminum. My second version should be cleaner and give alot more pedal feel as now Im actually addressing the vacuum system properly.
Old 12-10-2016, 11:37 AM
Now for the biggest problem I've had with this car in the year--a-half since I bought it. Before the supercharger and everything else I have added to the car I have always had this problem between 3000 and 4000 RPMs hesitating badly as if it hit a rev limiter. It pulls hard before 3000 and if I push past it it will pull hard from 4000 up to the 7000 rev limiter that I have on it now. It mostly does this when it's cold. If I let it sit there and warm up to full operating temperature it most likely will not do it at all. Besides all of the stuff listed above I have replaced the cam position sensor the crank position sensor the coolant temp sensor mass air flow sensor throttle position sensor both knock sensors and I rebuilt the Vanos once and wasn't sure if it was the problem so I replaced it. And I bought I used DME that tested good on another car. And I replaced the DME relay. The newest thing I noticed since I put the fic 6 on is now when I log data at that point where it breaks up badly it shows up that injectors 1 3 + 5 are running 500 to 700% above the DME output signal. My afr's go off the top of the scale lean. But as soon as I get to 4000 everything drops right back into place and it takes off again. I have never been stumped buy a car problem before in my life in over 25 years as a mechanic. But this one has got me. Worst of all it's my own car. I guess that's the way it is. Any help or suggestions would be greatly appreciated. I've been all over the internet and I can't find anybody else who had this same problem. My car idles good and drives good down the road. And if I wait until it is completely warmed up it runs perfect. But warming up has become more of a problem now since it's been in the 20s at night here in New Jersey.
Old 12-10-2016, 12:03 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Sounds like it's time to get an oscilloscope hooked up the one of the injectors so you can see the pulse train to verify if the DME is really changing the pulses to the injectors.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
