2006 Z4 3.0si Headlight lens - Bimmerfest - BMW Forums
Old 08-15-2016, 04:03 PM
burlovgolf burlovgolf is offline
Mein Auto: 2006 Z4
My headlight lens are very foggy. Are there available lens that won't corrode for my BMW.
Old 08-15-2016, 05:01 PM
pungo's Avatar
pungo pungo is offline
Mein Auto: 2007 Z4MC , Corrado G60
No, they are not removable. Sand, polish and coat with clear paint, they'll look like new.
Old 08-17-2016, 05:45 AM
q3131a q3131a is offline
Mein Auto: 2006 Z4 Roadster
Here is an overview of how to do it.
Old 08-17-2016, 07:34 AM
wdbii wdbii is offline
Mein Auto: a truck
I have a 2007 3.0si coupe. The lenses have a bit of a smoky tinge, is that normal or are they beginning to discolor?
Old 08-17-2016, 07:59 AM
bwitherel's Avatar
bwitherel bwitherel is offline
Mein Auto: 2006 Z4 3.0si
Buy a polishing kit. Takes one hour per side and is a 3 or 4 step process. Trust the process - will look worse after first step but will turn out beautiful. I did mine 3 years ago and still look like new (although garage kept). And DON'T spray with clear coat - that is a bad idea. Click image for larger version
Old 08-17-2016, 04:53 PM
pungo's Avatar
Why is that?
Old 08-17-2016, 06:22 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Originally Posted by pungo View Post
Why is that?
Some of the solvents in the paint can attack the plastic and cause it to cloud or craze.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 08-18-2016, 07:46 PM
pungo's Avatar
Hmmm, had the body shop guy put clearcoat on a pair of 535i headlights when he was spraying someones bumper over 5 years ago and they still look like new. I hear marine spar varnish works well too. If don't put some type of protection on them, they will haze over again.
Old 08-19-2016, 05:48 AM
bwitherel's Avatar
The clear coat will chip and scratch. The plastic headlights can be nicely buffed and maintained without any extra finishes.
Old 08-19-2016, 06:29 AM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
Maguires makes a nice kit. Worked great. Check out this video. BTW - I would mask the painted surfaces that butt up to the headlights with painters tape to protect the paint. Take your time and don't shortcut the steps and time for each.
Old 08-19-2016, 07:23 AM
zangxx zangxx is offline
The clear coat protects from further UV damage. A high quality clear like Cerakote (which is the same product used to paint mil-spec firearms) will resist most chipping/scratching. Why resurface only to let the sun have its way again? I'm all but certain that a properly applied quality clearcoat will solve the problem, not add to it.
Old 08-22-2016, 11:38 AM
Video Above
Here is a 2 year update
https://www.instagram.com/p/BC7Ov-zOjLe/
Old 04-25-2019, 11:52 PM
mkhounani mkhounani is offline
Mein Auto: 2005 BMW Z4
sanding does not work
Actually, I have sanded, used chemicals and bought all the best kind of product out there and none works. It last 4 months at best then it becomes even worst because the factory UV protection film will be gone and other ones are not even close. So, do it, but know that you have to keep doing it every so often.
Old 04-26-2019, 09:37 PM
papitosabe's Avatar
papitosabe papitosabe is offline
WalkTheWalk
Mein Auto: 06 Z4 Coupe
You can use 2k clear coat and it will last for years if prepped correctly.
