4D16 = $3627... Man I feel smart buying a BMW extended warranty - Bimmerfest - BMW Forums
Old 01-24-2017, 10:13 PM
ard ard is offline
Resident Curmudgeon
CEL two weeks ago. Pulled a 4D16
Dropped the car off at the dealer for that, plus some odds and ends (MAF rec all, airbag recall)
Tech ran required test plans, BMW tech services decided it needed:
Both Pre and Post NOX sensors
SCR Catalytic Converter
Exhaust Temp sensor
Reprogram
Total cost on the warranty claim was $3637. I paid $50.
I also had three recall items on the list, two completed:
MAF was replaced.
Driver airbag done
"No passenger airbags at this time"
Unfortunately this doesn't do a damn thing for anyone trying to deal with their own 4D16 codes- BMW just replaced everything that might have been part of the issue! My tech buddy was not in house when I picked it up, so I couldn't debrief as usual. Testplans results were sent to the mothership to review, and they made the call.
I'm a bit over $2k ahead on the warranty. 89k miles today.
Light on the hard data I know....
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 01-24-2017, 10:52 PM
Flying Ace Flying Ace is offline
Mein Auto: M6 GC ZCP; '12 X5 Diesel
Good.
My car had this set repaired before my ownership. Exact same list:
Exhaust Temp sensor
On the positive note, at least your air bag won't kill you and will perform its intended purpose of keeping you alive. That's a win for you anyway you put it.
2014 F06 M6 (oil rig fire)
2012 E70 X5 diesel (oil burner)
2008 E90 M3 (oil distillates guzzler- Retired)
2013 bicycle (oily chain)
Old 01-24-2017, 11:05 PM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
Yesterday, connected Rheingold, looking for anything battery related - high discharge warning.
Observed some faults stored in memory.
One of them was "4D16 SCR system, efficiency". No CEL was thrown, of course.
This is with new NoX sensor (pre-cat) replaced a few weeks ago. Properly calibrated in Rheingold.
Details tab for that fault has this info:
Fault description Monitoring of NOx efficiency (total efficiency range). Monitoring links SCR efficiency rating monitoring operations of efficiency rating range 1 and efficiency rating range 2.
If a fault occurs in one of these two efficiency rating monitoring operations, the appropriate fault code is set.
Condition for fault identification Monitoring takes place whenever the preconditions for SCR efficiency rating monitoring operations of efficiency rating range 1 and efficiency rating range 2 have been satisfied (depending on temperature range).
Control unit voltage: 9.5 V to 16 V.
Condition for fault memory entry The fault is entered if it has been detected more than the following number of times (fault debouncing counter): 4
Action in service 1. Check filling level of AdBlue, top up AdBlue.
2. Check that metering valve and urea/water mixer are correctly installed and check for dirt contamination. Clean metering valve with water. Perform metering quantity test.
3. Check for the quality of the dosed out AdBlue.
4. Check with SCR catalytic converter diagnosis system.
Fault effect and breakdown warning None
Driver information Malfunction indicator lamp
Service instruction - Check the function of the metering valve and clean with water, if necessary.
- Nitrogen oxide sensor upstream or downstream of SCR catalytic converter is implausible (note is a corresponding fault code entry), renew sensors.
- SCR catalytic converter faulty, perform system test with SCR catalytic converter.
Carry out the following service functions depending on which components have been renewed:
- AdBlue: SCR system adjustments and adaptations, AdBlue (long-term adaptation factor)
- Nitrogen oxide sensors: SCR system adjustments and adaptations, SCR exhaust sensor system
- Diesel particulate filter: Diesel particulate filter: register exchange.
- SCR catalytic converter: SCR catalytic converter: register exchange.
- Metering module: SCR system adjustments and adaptations, SCR metering module
- SCR tank system: SCR system adjustments and adaptations, SCR tank system
The fault cannot be deleted until the DDE has detected a functioning SCR system. For this purpose, complete a conditioning run until the Check Control message goes out. The fault memory can then be deleted.
Old 01-25-2017, 04:25 AM
ddsski ddsski is offline
Mein Auto: X5
Get rid of vehicle 1 day before warranty runs out.
2016 Range Rover Sport HSE Montalcino Red, Ivory (wifes)
2011 BMW X35d Vermillion Red, Cinnamon Brown leather (good riddance)
2012 Mazda MX5 GTPRHT True Red
2011 Lotus Evora S Persian Blue
2008 Isuzu Ascender Lux the worker
Old 01-25-2017, 05:42 AM
1bad540's Avatar
1bad540 1bad540 is offline
wow, great save!!
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 01-25-2017, 08:18 AM
smuggymba smuggymba is offline
Mein Auto: 2011 X5 35d
Exhaust Temp sensor
Reprogram
MAF was replaced.
Driver airbag done
I guess that's where I made the mistake by going with Routee66 instead of BMW warranty. I did read extensively and everyone seemed to recommend Route66 (they don't cover emissions and that's the big issue).
Is it possible to get BMW warranty now (Route66 will refund). I'm at 6 yrs and 48K.
Old 01-25-2017, 09:21 AM
ard ard is offline
Resident Curmudgeon
Yeah, given my issues with the 2010 I lemoned, I wanted something that covered emissions.
No, 4/50 was the limit
Old 01-25-2017, 09:42 AM
zinm zinm is offline
Mein Auto: What I drive
Ard, How can I buy BMW extended warranty? Thinking about to pick up 2011 64k miles this saturday. Thanks.
Old 01-25-2017, 10:22 AM
edycol edycol is offline
Mein Auto: 328i xDrive 6MT
Go to local BMW.
Old 01-25-2017, 10:24 AM
ard ard is offline
Resident Curmudgeon
You cannot...you are outside of the BMW new car warranty period of 4 years or 50k miles
Old 01-25-2017, 10:30 AM
So basically you got what BMW sells as CPO when they sell car? 6/100?
Old 01-25-2017, 10:52 AM
Originally Posted by edycol View Post
Go to local BMW.
just to clarify, if your BMW is out of the original 4/50, you can still buy an official BMW extended warranty, albeit with higher pricing. (There is a drop-dead date of when you can buy this after original 4/50 expiration) Further, a BMW extended is a competitive financial product sold through the finance department at each franchise. As such, like buying a car, you don't HAVE to buy it at your local dealership. Not all dealerships are willing to sell you one without seeing your car first hand, but I know of at least 2 in CA that will sell it to anyone in the country if you provide appropriate documents online.
As a buyer of this warranty, it always helps you to call around and get the best price possible. There's a MSRP with markup for this product just like anything sold at a dealership, so you can find these at slight discounts.
Now if you already have a CPO tag, you likely won't be able to buy another BMW extended warranty. That 2011 if not CPO'd might just be outside of the drop-dead date for an official BMW warranty.
Old 01-25-2017, 11:33 AM
Thanks for great info. I"ll try to shop around from local dealers. I just got a quote from carchex for 3 years/37000 miles for $4469. Much appreciated.
Old 01-25-2017, 12:55 PM
Step one would be to see if your car is too old to be eligible for BMW warranty. Call VIN into local dealership
Old 01-25-2017, 05:56 PM
DjD-X5 DjD-X5 is offline
Mein Auto: '13 X5 xDrive 35i Premium
Exhaust Temp sensor
Reprogram
MAF was replaced.
Driver airbag done
Was the driver air bag a temp new but bad bag or a final answer?
Dennis,
Old 01-25-2017, 07:19 PM
ard ard is offline
Resident Curmudgeon
Do you have a reference for this??
You can buy the BMW 'power train only' warranty after the 4/50, but it is somewhat limited.
The Gold and Platinum plans have (or had according to you post) a hard limit.
Old 01-25-2017, 07:20 PM
ard ard is offline
Resident Curmudgeon
They had the driver bag available and replaced it. The passenger bag will be done later
Old 01-25-2017, 08:30 PM
I'm still confused on what it'll take to get my airbag replaced. Obviously, it doesn't appear they were calling you in anytime soon to do the bags, but when you need work done in the shop, all the sudden it is available?
Old 01-25-2017, 08:43 PM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
Exhaust Temp sensor
Reprogram
MAF was replaced.
Driver airbag done
I know you are out of California emission warranty. Had this occurred under 7 years or 70 k miles, it seem to me it should be covered under those warranty? Is that correct assumption or not.
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 01-25-2017, 09:59 PM
RPsX5d RPsX5d is offline
Mein Auto: X5 35d, MY2011 150,000 mi
I think what ard got replaced is the "temp new" or the interim repair (newly manufactured inflator), not the final replacement . . . see attached Q&A.
I don't think the final solution is out yet.
File Type: pdf BMW X5 - RECALL - Airbag Driver - Q&A.pdf (148.3 KB, 59 views)
Old 01-25-2017, 11:07 PM
ard ard is offline
Resident Curmudgeon
Correct, those parts would be covered under the CA 7/70
Oh, yeah- sorry. That is correct
Old 01-26-2017, 02:33 AM
split71 split71 is offline
Mein Auto: '19 440 GT, '06 M5, 530
Curious as to how they decided to replace the air bag. My '11 X has been in Fl it's whole life and can't get the air bag replaced. Dealer can't seem to get them (updated or original style)...
Old 01-26-2017, 03:34 AM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Tell your dealer you (or you wife) is scared to death driving the X5 and demand that BMW provide you with a loaner that you can drive around while you park your X5 in your garage. This will speed up the replacement process exponentially. I got the driver side airbags replaced on my two X5's within two months after getting the loaners. I live in GA.
Old 01-26-2017, 08:30 AM
To do it without you initiating it seems like a money ploy on their part as your X5 isn't on the critical list. Perhaps the amount of recent wet weather has triggered some concerns!
Dennis,
Old 01-26-2017, 08:40 AM
TroubledGnome TroubledGnome is offline
Mein Auto: 1988 M3, 2011 X5 35D
Mine was replaced at last years state inspection with no provocation from me.
