1 - 5 of 5 Posts
since i've had the car, which is an auto, i can change gears merely by moving the stick. it glides with relatively no force from park to reverse drive etc. should this fix just require something like a new gearbox (what is this actually called?)?
Are you talking about the gear shift mechanism below the handle or the whole transmission( the gear box).
East Bound And Down
do you mean u dont have to depress the brake pedal to move it from park to reverse?
or that it doesnt stay in one selected spot...
if its the first than its a matter of adjusting
if its the second do a manual conversion :)
my friends old car was like that to he didnt have to do any thing with the brake
if it was me i would get it fixed that way your not driving down the high way and put your can in park i have done this to a car and well it not good
Premium Member
how the hell do you do that? drive is nowhere near park!
you just need a new shifter knob. take the knob off (via 6mm hex on the front side of the handle), and then replace the white plastic piece that comes out with it.
1 - 5 of 5 Posts
