I just recently acquired a 00' z3 m roadster. When I got it I noticed it had a cheap DUAL head unit and there was speaker wire wrapped around the seats. Upon further inspection I found everything to be wired up right but I do not have any sound at all. I tore everything down today trunk carpet and rear deck carpet and started tracing wire still have not found any problem. I suspect I have a bad amp (which is $200 to replace).
SO FOR THE ADVICE
I've been thinking that I could remove the amp wiring and run the speakers directly to the head unit (which I would replace as well). With the money I would save from not replacing the amp I would be able to replace all my interior speakers and be able to run an aftermarket amp later on that would by far produce better sound than the stock z3 system. I was going to remove the middle speaker from the back, keep the two rears, floor, and door speakers. Any advice before I undergo this project would be greatly appreciated.
Thank you in advance!!!
Just thought of another question since I am pretty sure i'm going to do this. Where should I run the 12v constant and switched wires to or should I just keep those wires original?
SO FOR THE ADVICE
