1 - 7 of 7 Posts
My CA found it somewhere in the trunk but don't know exactly where.
In 06, they stopped putting them on them in the trunk. You need to get a dealer to pull it for you.
Not doubting you but mine is an 06 and they found it in the trunk.
Chitown-Irish is correct. my 3/06 production model is also located in the trunk as is a co-workers 1/06 production model:
its located in the trunk, behind the left nav access panel on a silver "TCU" module about the size of 2 vhs tapes stacked together. if you look at the eject button on the nav player its located just to the right and is installed on about a 45 degree angle.
there is a white lable with the "PK" on it. i used a small telescoping mirror but you can also slightly pull back the trunk liner above the unit and it will be easily located.
1 - 7 of 7 Posts
