1 - 10 of 10 Posts
After reading some previous post on this topic here is what i am planning to do
Tranny: Royal Purple Syncromax
Diff: OEM (aka Castrol SAF-XJ) WITHOUT FM
(I think the revised oil (MTF-LT-2) fluid doesnt have FM...and I called my local BMW stearlership to confirm)
It seems like you can get the SAFXJ fluid fairly easy these days (since the Skyline and other cars uses the same fluid)
http://www.amazon.com/GT-R-NISSAN-DIFFERENTIAL-FLUID-SINGLE/dp/B00315PLSW
for about $40 a liter
or here
http://www.speedforsale.com/nissang...ential-fluid-castrol-safxj-75w140-p-1159.html
different package...but same stuff
Correct?
Also how much fluid do i need?
Tranny: 1.5Liter?? (that's what the local stealership told me....but it seems VERY low....shouldnt it be about 2-3Liters??)
Diff: 1.1Liter??
Also planning to get some new tranny mount....UUC or Rogue ??? I saw some good reviews on the Rogue.....anyone got the UUC mount?
Some Say...he apexes late
That little book that came with the car...
page 41:
Bad Lieutenant
I'd go with the Rogue tranny mounts, UUC isn't too great at customer service and the rogue is plenty beefy with zero added NVH.
Discussion Starter · #4 ·
coolio thanks!
Aren't the M Model Zs supposed to get the BMW fluid with "FM". Or is this expensive fluid required only if the diff makes noise? Confused.
Discussion Starter · #8 ·
So is it 1.5 or 1.8L?
Also what would you recommend FM or no FM?
No FM for me.
You'll need two liters/quarts and pump it in until some starts dripping out of the fill hole. Insert new O-ring plug, torque, and you are done :thumbup:
1 - 10 of 10 Posts
