My car's entire DME/electrical axis has freaked out, trying to figure out what the hell happened...
Background:
'07 e90 335i sedan, manual trans, 150K. Battery replaced & registered Dec 2013. I believe the [electronic] water pump was also done recently, not 100% sure. I replaced a bad crank angle sensor in Feb and a broken rear window regulator Saturday. Driving fine until:
Symptoms:
Parking on a hill, I accidentally stalled by popping the clutch in gear while holding brake pedal. I remote-locked & left it for 3h (w/o hitting the stop button). Came back to a dead battery--wipers and interior lights had been going haywire the whole time. After using physical key & a jump from AAA, it drove fine for 40 mi before going nuts again.
With a recharged battery (trickled at 2A/12V overnight), external CA locking/unlocking works & engine starts promptly, but with these symptoms:
No way to pull codes and can't see verbose iDrive messages. But I hope this rings a bell for someone. I first suspected the AAA jump start, but now believe it was this electrical freakout cycle that killed the battery in the first place while parked...so what caused it? :dunno:Battery obviously starts the car (repeatedly), but could it be faulty in some other way? Did I trigger some ABS/DBC module weirdness when I stalled it? Thoughts much appreciated!
Background:
Symptoms:
- DSC warning
- DBC warning
- ABS light
- start-off assist inactive warning
- airbag light
- yellow battery light [NEW AFTER TRICKLE-CHARGING]
- auto wipers start going & won't shut off
- power windows won't lower/door lock & DTC console buttons inactive
- dash & interior lights randomly flicker (drained battery only)
- iDrive/nav screen goes blank, comes on only erratically.
- yellow and red temp/overheat warnings come on in quick succession while driving (when warm, haven't tried cold)
- on temp warnings, first get limp mode power (yel), then no power at all (red), tho the engine doesn't stall & temp gage stays in normal position.
- HVAC system won't blow hot air when engine warm.
- Minor coolant seepage (~50mL) @expansion tank gasket--doubt it's related.
- Serpentine belt intact, alternator pulley running.
- Radiator fan not running @idle when temp warning displayed.
