Is it that hard? Are you doing the part on the trunk or the body? On the trunk, there were some tabs I pulled out for the trim, then pull back the foam, then the bulb assembly just unclips.
I would use OEM parts - if the resistance isn't just perfect, it will set off that irritating warning light that your bulb is out. Its a friggen headache.
