1 - 6 of 6 Posts
Car is making noise like I have a flat. Front left. It's only making the noise at high speeds. 65mph plus. I would compare the noise to a tire tread seperating and unraveling..... what should I have checked ...... ? Help me out Bros!!!! Lol
Achtung! Hochspannung!
2018 i3, 2020 Arcimoto FUV
Moved to E65 subforum.
And the easiest check is your tread wear, if the tread is heavily feathered or cupped it can create a good deal of noise. Otherwise the wheel bearing is the likely suspect, does it get worse/better when turning left or right?
Do you have run flat? If so these tires often are suspectible to road noises. Replace with regular inflatable tires might solve the issue. Do alignment soon after you replace the tires.
1 - 6 of 6 Posts
