Since Ive owned the car 5 failures.
In the last 6 weeks, 11 failures
Since 1/2011, 15 failures
I love the car, but we may begin a love/hate thing here soon. I wonder now If I got a lemon?
Luckily it came with an extended warranty to 2015. Repairs from 6/14 were done under the extended warranty. Prior to that repairs were done under factory warranty.
REPAIR HISTORY
Date/ Failure Description/ Covered by Warranty/ Note
8/3/2012 Driver restraint failure. Replaced driver seat switch pad. /Yes
7/1/2012 Wipers actuate when engine starts. Replaced wiper switch /Yes
7/1/2012 Fuel tank vent blocked. Replaced charcoal canister / No Filters not covered
7/1/2012 Rear door vinyl loose causing shades to detrack. Glued down vinyl /No Upholstery not covered
7/1/2012 Bluetooth Operates Randomly. Replaced TCU /Yes
6/14/2012 Parking Brake malfunction. Replaced parking brake module /Yes
6/14/2012 Vacuum pump leaking oil. Replaced vacuum pump. /Yes
6/14/2012 Front thrust rod bushing coming apart. Replaced bushings /Yes
6/14/2012 Front control arms coming apart. Replaced control arms. /Yes
6/14/2012 Transmission is leaking. Replaced trans sealing sleeve / Yes
6/14/2012 Driveshaft Guibo coming apart. Replaced guibo flex disc. /Yes
10/25/2011 Coolant leaking. Replaced lower hose and sensor /Yes
10/25/2011 Seat bottom leather loose. Reattached leather /Yes
10/25/2011 Door sill plates peeling. Replaced door sills / Yes
1/3/2011 SES light is on, Engine running rough. Replaced ignition coils /Yes
REPAIR HISTORY
