19" Apex PS-7 (Anthracite) w/ Pirelli P-Zero Nero GT tires
Selling a set of 4 Apex Racing PS-7 19" wheels.
They have Pirelli P-Zero Nero GT tires on them with less than 1000 miles. Picture shows the previous tires (BF Goodrich GForce)
These are a staggered set:
Front Tire: 235/35 R19
Rear Tire: 265/30 R19
-Comes with gloss-black APEX center caps
-Accepts OEM Roundel center caps (also shown on vehicle)
-Installs using your factory lugs or a stud conversion
-BMW hub-centric - no centering rings
-Accepts all wheel spacers including 5mm while still remaining hub-centric
-TPMS compatible
"PS-7 Product Information:
Just like the rest of the APEX wheel line, the PS-7 is once again produced using the Flow-Forming manufacturing process. Flow-Forming, which has also been called "Roll Forging" or "Spin Forging", produces a barrel with similar strength to that of a fully forged wheel. This significantly reduces weight in the most significant part of the wheel, as it has the greatest impact on rotational mass. Even with key strength improvements that add weight in select areas, static weights are reduced by 20% on average versus cast alternatives.
More aggressive wheel widths and offsets were selected versus our line of race-oriented wheels, allowing for a flush fit without spacers. Initially available in 18" and 19" diameters, the PS-7 is produced using three unique face profiles with increasing spoke concavity. We designed these these face profiles to significantly increased concavity on many applications that are traditionally more conservative. A total of 17 BMW specific sizes in three finishes are initially being released.
Strength improvements were made to help specifically address the unique abuses of the street where low-profile and stretched tire fitments are used. To help fight wheel bends, we've increased the thickness of the wheel's inner lip. Load ratings exceed JWL requirements, and all sizes have been crush tested in Japan, earning them official VIA certification and registry marks. Additionally, the barrel's diameter increases sharply after the drop center, improving big brake kit clearance.
Performance luxury vehicles deserve much more than heavy cast wheels. The PS-7 combines racing inspired lightweight engineering with desirable street styling, to produce the ideal wheel of choice."
Minor curb rash on one front, small chip on one rear, and slight scratches in some lug holes.
List Date: 10/25/2016
For more info, click here to view the original listing: 19" Apex PS-7 (Anthracite) w/ Pirelli P-Zero Nero GT tires
This item is no longer available.
-TPMS compatible
