1 - 20 of 25 Posts
So, I'm fairly new to older BMW's so I apologize in advance for my ignorance! I just purchased this car from a close family friend who's had it since new. He took fairly good care of the car, but I'll be tinkering with it for several years I'm sure! First and foremost I've had to tear into the roof since the electric sunroof wasn't closing all the way. After narrowing the problem down (almost) to the lifting roof transmission I am still confused as to how the whole thing works. I guess I'll see after I install the new transmission if it works!
I'd like to take out both front seats for cleaning and some minor repairs to the seats themselves...how on earth can I get to the rear bolts for removal? :dunno:
Discussion Starter · #3 ·
Thanks man. Seems as though my height adjustments aren't working and of course they're both at the lowest setting. I'll have to figure out how to get them to work in order to get at the rear 2 bolts and finish taking out the seat brackets.
lol. so its a manual seat adjustements i guess, since its an old model and of course unless the previous owner hasnt upgrade the seats with the electronic option! it will be a lot easier if you spRAY some 4wd and get off the seat. with weight on the seat its harder to adjust ! hope it helps .
Discussion Starter · #8 ·
Okay here we go...not great pics, but I'm working on it! The dry one is when I picked the car up in Ketchikan, AK and the snow pics are from when I picked it up in Whittier, AK after she traveled up on the ferry. We're both happy and warm in Anchorage, AK now:)
Discussion Starter · #12 ·
Sunroof Repair
Thanks for the thumbs up guys! Anyone know of how I can get a base plate for my sunroof transmission? I've installed the new transmission, but it didn't come with the $3.00 base plate which holds the pinion in place. Every company I've company I've contacted says it's no longer available. Please suggest if you can!
It's item number 8 on the attached image. Part Number 54121857909
Try getbmwparts.com; I popped your part number in and I was able to add it to the cart. Of course shipping will cost 5Xs the part cost. :eek:
Discussion Starter · #14 ·
Thanks man. I'll try that site as well, but it comes up available on penske and bimmer.com as well and then they email saying it's no longer available. I've thought about going to a machine shop, but in Alaska they like "bigger" jobs! lol
catso
Try Pelicanparts.com, ECSTuning.com or email [email protected] (also a Bimmerfest sponsor).
My turn signal suddenly stopped working today. What could be the problem. Relay switch, bulb burned out, fuse? Brook
All of the above. By relay are you referring to the flasher?/ The one thing you missed is on the early, E12 chassis cars, all the lights and turn signals route through the emegency flasher switch. So if that is bad, it can and will affect your turns etc.
No turn signals are working, neither on the left side nor right. And the indicator on my dash does not work either. Think Bert may have a good bead on this, the hazard flasher switch is bad. SOOO, question, where can one buy a new switch, at an auto parts store in Denver perhaps???
You will probably not get that at a regular parts store. I may have a good one if you are interested. If I do, $35 plus $5 postage. When you say yours is bad, what makes that determination?/ Does the button not stay in(engaged) when depressed?? That would be the give away as to it's condition.
1 - 20 of 25 Posts
