1 - 4 of 4 Posts
well I'm new to this site and new to beemers and i recently received an 86 325e that wont start it was my dads hasent ran in years but cranks over no problem , not sparking and not getting fuel , fuel pump works too . could it be be bad ecu or crank position sensor , its getting spark to the coil just Not to plugs . I was looking up as much as i can but im too sure , please help im a nooob at these things . thanks to the max
livin large
things to check- makes sure the cam moves when you crank the engine
then crank position sensor wire - wire good, then change sensor.
from there, then you can start to suspect the ecu.
1 - 4 of 4 Posts
