1 - 6 of 6 Posts
I am experiencing a parasitic load on my bmw. I notice the main power relay is always active. It stays hot. I cannot figure out why. Can anyone shed some light on this for me.
the contacts might have been burnt and stuck together. take it apart and clean the contacts with a sand paper
Discussion Starter #3
Power drain problem
In have a 1986 325es with a parasitic load. I notice the main power relay does not shut down. It is hot to the touch unless I disconnect the battery. Does anyone know how to test this car for the problem. Could it be an ignition switch?
Bimmerfest Founder
Welcome to Bimmerfest! I've moved your question to our E30 3 Series forum, you'll get more help in here.
Tim
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
^ That.
You can narrow it down quite a bit by pulling the negative battery clamp, putting a DMM between the post and clamp set to amps, then start pulling fuses one at a time until you hit one where the draw goes away.
1 - 6 of 6 Posts
