1 - 3 of 3 Posts
Froze as in ice/cold weather frozen or as in stuck mechanically? My lock froze due to weather, and I used the trunk lock with key and locked and unlocked the locks repeatedly while someone held a blow dryer to my driver's side lock area, and that did the trick. If it's 'frozen' mechanically, then I guess you have to try to take it apart. I also sprayed lots of graphite into door lock to help loosen it up a bit. Be careful not to snap the key off. It happens! Good luck.
1 - 3 of 3 Posts
