1 - 3 of 3 Posts
Hello to all the BMW fans.
I am new to the site and I could use some help.
My 1989 325c has a new starter courtesy of the owner, me.
I was able to make the change without any major disassembly, just some intake and vacuum lines removal and wire harness movement.
Happy to report the starter works fine. The engine is running rough, idle is around 500 rpm with down revs to maybe 300 then back to 500.
I found a line from the canister without a connection to the engine. Anyone recognize this and can explain where the hose barb connection is for this larger diameter hose?
Would this disconnection cause a rough or low idle?
(Hope the picture is attached)
Thanks for your help
Greg
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
It goes under the throttle body, almost against the manifold. It's really hard to locate without taking the throttle body off to acquaint yourself with it's location.
1 - 3 of 3 Posts
