1 - 8 of 8 Posts
About 3 years ago my car had a cracked cylinder head. I had not driven it since this incident occured. I recently put a rebuild cylinder head on about a month ago. Now when I go to start it up it turns over nicely, but the engine wont fire. I replaced the fuel filter, cleaned gas tanks, replaced battery and put fresh fuel in, but the car still wont fire up . Volt-meter shows voltage with car ignition on for 6 coil wires. My father thinks it might be the 6 coils sitting 3 year without use and possible ECU (electronic control unit). Any suggestion?
Humble E34 lover
Hey Bimmerman. Welcome to the Fest. You may have a bad fuel pump or fuel pump relay. Testing both is relatively easy. Shoot me your e-mail in a PM and I will give you more info. I just recently had to replace my fuel pump relay. Piece of cake. $15 dollar part retail at the dealer.
Discussion Starter #4
Try taking out one of the spark plugs and see if your getting a spark when you try to turn it on.
Tried it already, no go. Pulled a plug and tried to spark one coil, still no go. Volt-meter tested electrical lines to each coil and had hot wires to all 6 with car ignition on.
Discussion Starter #5
There is fuel pressure at the fuel filter when turning the car over.
Discussion Starter #6
On second thought you might be right. My father just told me not too long ago that there is no fuel is going through the line now. I guess the fuel we saw pouring out when removing the fuel filter was the old gas from years back.
Humble E34 lover
I was going to e-mail you a copy of the Benlty manual. It tells all about how to check the fuel pump and fuel pump relay.
You can get it at this link:
http://www.mikerophonerecords.com/bimmer/
This should help. Also, search for fuel pump relay or such and you should be able to find tons of info on how to troubleshoot and fix it.
1 - 8 of 8 Posts
