1 - 2 of 2 Posts
Okay so I'm currently rebuilding my M50 Motor, and thanks to tax return time I have enough money to buy a donor car for a manual swap. I found a cheap 318ti (no motor) but I can't find much online about swapping its manual into a I6 e36. What I have found is that the 318s use the same Getrag transmission as a 325i with a manual would have. I know I would need to buy a driveshaft still, but would everything else for the swap work? I'm keeping the 3.91 Diff already in my car as well. Would the clutch pedal assembly, master cylinder, and lines all be the same?
Thanks for any help!
Screamin demon
Yes. Hydraulic assemblies are the same. To use a getrag you just need the getrag clutch, and the getrag shift linkage arm.
1 - 2 of 2 Posts
