1 - 7 of 7 Posts
Hey i recently bought a 1992 325i e36 coupe and my driver side electric windows go down perfect but they dont come up, it doesnt seem to be engaging and i was wondering if any knew how i could fix the problem?
, thank you
Have you checked the up/down switch? Swap with the passenger side or sunroof if you have a sunroof.
Could be the window regulator motor. If you need one let me know very expensive to replace.
The Canadian Prick.
By very expensive, you really mean fairly reasonably priced right?
(I am NOT saying that this is the OP's issue, as I really have no idea, but here's the prices from Rock Auto):
Thought you had a problem going up?
There is a plastic guide inside the regulator make sure to clean and its not damaged.
slow down... :D
check fuses
check relays
check microswitches
Your windows are just confused.
1 - 7 of 7 Posts
