Notice the notched plastic door by pipe connecting into coil, also had to delete a plastic armature on driver side which held up some electrical device by way of push pin in order to install pipes as a complete unit. Absolutely no forethought on BMW’s engineering concerning coil replacement as well as Evap coil. It’s redickalous. No wonder service is outrageously $$$$.
Latest update: after tearing apart the upper and lower manifold , timing chain cover. 2 new knock sensors, one crankshaft position sensor, bought a new cam sensor but the connector was backwards, used old, 4 new coils, valve cover , front crank seal, new heater coil, new wires, new fuel filter , new catalytic converter, various new heater hoses and vacuum hoses, I still was able to replicate the hesitation on the freeway, and intermittent abs light. Today installed one new right front and rear left sensor, cleaned up 4 speed rings, and installed a brand new…wait for it…..Hella fuel pump. Test drive was so great, no hesitation, plenty of power 70-90 mph, no hesitation, no abs light in a 29 mile test drive. It’s running real good (knock on wood) the original fuel pump looked fine except the strainer was petrified and was totally black. Not sure if black was the color new , but the new one is white with a plastic rib cage to keep a blimp type shape . The old strainer was fairly flat. Oh my, please let this be the fix!! Will post pic of black strainer later. This car is a little highway rocket hope it stays.
