My 1995 525i is running rough all the sudden. I tested with a Peake 5 tester, and it came up code "10". According to the chart, that is the Crank Sensor. The car runs rough at idle, and sputters a bit while pushing gas. As RPM picks up, the sputter disapates, but is still present. It runs like it is missing a cylinder, or out of timing. It happened after running through some deep water, if that has anything o do with it?
Q: Is it ok to drive until I replace this part?
Q: Is this the cause of the problem? I tried the "stomp test", with no results, but think the Peake is pretty accurate.
Q: The Bentley book says the cr won't start with a faulty Crank Sensor, but my car starts and runs? Is this just a preliminary to the end of this sensor?
THanks to whoever can help!:thumbup:
:dunno:
