Good day All,
I recently removed the diesel injection pump and replaced all the gaskets due to minor leaks in several spots (I used the special tool to hold the timing chain in place as well). The car started prior to the rebuild and ran fine. After the re-build the car turnovers, however, it does not fire. I double checked all the sensor connections and hoses and they are all properly connected. On the clean side of the fuel filter, fuel flow is visible and appears to be getting to the injection pump. Is there some sort of adjuster on the injection pump that I may have tightened down too much? Any help would be much appreciated.
