Parts I need
Hello,
I need the following:
1- Glass break sensor and Alarm indicator LED. I'll take any configuration you have available.
2- Antenna Base F short rod 65218375159
3- Towing hinge 72157203519
4- Inclination indicator: 65758389881 or 65756923210 with the mounting bracket, hardware and pigtail body connector if available 4" of lead on the connector should be plenty.
5- Both seat belt guides 51478398965 Both Driver and Passenger should be the same. Only if the covers are intact and not broken. Note the screw covers are for production dates upto 12/96. They are delicate so remove carefully.
Please state terms to include shipping & handling to Danbury CT 06810 via the most economical carrier service with tracking if possible. I am actively seeking these parts, in several venues, so if you can give me an itemized cost for each that would be very helpful.
Thanx's in advance Hern
