I've recently run into problems with my 323.
1. The connector for the radiator to the hose broke so I replaced the radiator. I replaced both hoses as well. Now the temperature gauge is going red. Could this be it needs bleeding? If so, how is this accomplished. If not, what else should I look at and change.
2. My brake replacement light just came on as well, it's the circle with the curved line on either side. It's lighting up rad, but the owner's manual indicates if it lights up yellow, the brakes need changing. What does it lighting red mean.
How can I tell which brakes need changing?
What parts do I need to order for each set of brakes.
And can someone please tell me the process of replacing the brakes.
Thanks for the help.
