1 - 3 of 3 Posts
hello...i hope someone can help. my heater will not stop blowing hot air. it seems to be stuck on 75 degrees farenheight. tried turning the heater of but still i can feel hot air while driving. Pls help. Also my ac will not work. where do i start. do i need to charge with freon?
this sounds like it could be a heater control valve failure. i would try seeing what comes up under ''heater control valve' in the search function.
as for being low in refrigerant, it may be that as well, so i would check the vent temps with a thermometer to see what it is at the vent.
i would also check to see if the compressor engages. if it does not engange, then that could indicate a low system. another (more accurate) way to check the ac system is to hook up guages and get a reading.
these tests will point you in the right diagnostic proceedure. the results would determine the best route to go from there.
good luck.
df
1 - 3 of 3 Posts
