S52, 77,200 miles, 5 speed manual transmission, limited slip differential, 240hp. Arctic Silver over black Napa leather, newly refinished shadow chrome Roadstar wheels, power seats, heated seats, seat tilt mod. No accidents. The car drives great and is the last truly analog M Roadster without traction control.
This car has been extensively serviced by me (Technical Editor and Board member of the ZSCCA) using either genuine BMW or OE (or better) parts, at the current mileage. A real turnkey car that won’t need anything for several years. There are zero mechanical or electrical problems. Power convertible soft top is fully operational. A/C blows cold. Trunk floor welds are solid. New front pads and drilled rotors at 74,000. Rear pads have 8mm left. No rust, no body damage and paint is excellent aside from the typical road rash on the front bumper cover. Goodyear Eagle Sport A/S tires have 7-8/32” (75%) tread. H&R Sport springs with original shocks/struts, Magnaflow exhaust, Racing Dynamics strut tower brace, Dinan throttle body, cold air intake with K&N filter. Comes with the very uncommon fog lights, tonneau cover and wind deflector. All polyurethane bushings listed below are street-level poly.
Repairs and upgrades:
Radiator / upper & lower hoses
Thermostat with metal housing
Metal impeller water pump / metal pulley
Expansion tank / cap / hoses
Feed and return hoses to heater core
Throttle body coolant hoses
Alternator and AC belts & tensioners
Aluminum power steering pulley
Brake and clutch hoses / fluid flush
Brake booster hose
PCV valve and hoses
Coolant flush
Fan / fan clutch
Viton seals and gasket for VANOS
VANOS feed line
Motor & transmission mounts - stock rubber
Flex disc
Oil pan gasket
Oil filter housing gasket
Valve cover gasket
Throttle body gasket
Intake manifold gaskets
K & N air filter
AKG polyurethane front control arm bushings
Rear trailing arm bushings - stock rubber
AKG polyurethane differential bushing
AKG polyurethane subframe bushings
Powerflex polyurethane front and rear sway bar bushings
Rear sway bar end links
Antenna grommet / antenna
Liqui-Moly 5W-30 motor oil / filter
Redline 75W-90 differential oil
Redline MTL transmission oil
Redline ATF power steering fluid flush
Driver’s seatbelt guide repair
Seat bushing repair
Fog light bulbs
Wiper blades
Headlight refinishing
Full interior and exterior detail with 2 stage paint correction & sealant
Rear plastic window defogged and polished
Hood and trunk badges
Trunk lid struts
Sagging glovebox repair
Clean title
Clean Carfax report
Brake booster hose
PCV valve and hoses
Coolant flush
Fan / fan clutch
VANOS feed line
Flex disc
Oil pan gasket
Valve cover gasket
K & N air filter
Seat bushing repair
Fog light bulbs
Wiper blades
Trunk lid struts
Clean title
Clean Carfax report
