1 - 5 of 5 Posts
Okay, my car wouldn't start so i tried to jump it multiple times, only to find out that the negative cable was loose and not making a good connection. Tightened it up and started right away. Now the car runs great, but the damn CHECK ENGINE LIGHT WONT GO OFF!! Tried resetting it with a Snap On Modis...no luck. I am dreading taking it to the dealer. CAN ANYONE HELP!?
HERE ARE THE CODES (LOTS OF THEM)
P0720 OUTPUT SPEED SENSOR, CIRCUIT MALFUNCTION
P1750 MANFACURER CONTRL. TRANSMISSION
P1751 MANFACURER CONTRL. TRANSMISSION
P1749 MAFACURER CONTRL. TRANSMISSION
P1748 MANFACURER CONTRL TRANSMISSION
P0732 GEAR 2 RATIO, INCORRECT
P0735 GEAR 5 RATIO, INCORRECT
P0740 TCC, CIRCUIT MALFUNCTION
P1747 MANFACURER CONTRL. TRANSMISSION
P1770 MANFACURER CONTRL TRANSMISSION
P1765 MANFACURER CONTRL TRANSMIISION
P0705 TRANS RANGE SENSOR, CIRCUIT MALFUNCTION
P0705 TRANS RANGE SANSER CIRCUIT MALFUNCTION
P0763 SHIFT SOLENOID C CIRCUIT ELECTRICAL
ANY HELP IS REALLY APPRECIATED, THANKS!!
Protect your (lug) nuts
Holy crap, your transmission is going kaput!
Hmm, cant help you here. that year/model is nothing but trouble. :(
Discussion Starter · #5 ·
okay, tried disconnecting negative cable, and resetting with a snap on modis.
Is there any other way to reset the computer and get this check engine light off??
1 - 5 of 5 Posts
